Relay Question
Old Feb 23, 2004 | 02:02 PM
Buck89RS's Avatar
Relay Question
I was looking at the autozone site for relays, there are two relays that i am not sure as to what they do. The first is the " Burn Off Relay " what is it and what does it do? What happens if it is disconnected? Also the " Wide open throttle cut-off relay " Same questions with that one too. The cut -off relay would seem to be a problem to me. If yall know what im talking about. Let me know your thoughts and how to disconnect the cut-off one. Thanks
-Buck
Old Feb 23, 2004 | 02:22 PM
Marc 85Z28's Avatar
The "burn off relay" you are referring to is for the MAF sensor. It is known as a MAF burn off relay. All it does is provide power to heat the MAF sensor to burn off any accumulated dirt and debris on the sensor filaments.
The "wide open throttle relay" is a relay that cuts power to the AC compressor when you reach wide open throttle for extra power. I don't believe any thirdgen ever came equipped with this, but I may be wrong. Almost all newer cars have it though.
Old Feb 25, 2004 | 02:29 PM
citizendan1st's Avatar
maf burn off relay location..
can you tell me where the burn off relay is located?i need to replace it...thanks..
Old Feb 25, 2004 | 02:34 PM
Buck89RS's Avatar
Every where that i have read says " On the firewall next to the Brake booster. " I think there is someting like three or four on mine ( different relays ).You will just have to find out which one.
linz
Oct 22, 2015 07:59 AM
Scottyboy
Feb 11, 2015 10:28 PM
Jeff1904
Jan 3, 2015 12:00 AM
kandied91z
Aug 6, 2002 02:01 PM
kandied91z
Aug 6, 2002 01:18 AM
