rearend tech.
Does anyone know which 3rd. gen. camaro rearend is the best? I have a 84 Z-28 5.0 H.O. with a 383 stroker and a 4L60 trans. but my rearend is a whimpy 7.5 10 bolt.I heard that a 88 up IROC rearend was the best because it has a 7 5/8 ring gear and 28 spline axles,oppossed to the 7 1/2 ring gear and 26 spline axles in my 84 rearend.Is that true? I would appreciate any info on this matter,thankz *Robin*
Some of the thirdgens 87 and up came with the rare australian 9 bolt rear end, I heard those are stronger then the 10 bolts, anyone feel free to flame me and correct me if im wrong
1988 Camaro IROCZ "MIDNIGHT CRUIZERS"
305 ci Tuned Port 700R4
3"Exhaust/Flowmaster 80 series muffler/Dynomax high flow cat/CutOut
hypertech chip/k&n filers, cut MAF screen gutted air box
"Theres no replacement for displacement"
My Iroc web page....
www.geocities.com/bobfitz82/index.html
Here is a site to help out with 9 bolt info:
http://www.difftechnics.com/9_bolt_home.html
1990 Camaro RS
1991 Acura Integra LS
http://www.geocities.com/joecool_2u/
LT1 swap in progress.
XE 230/236 cam, 1.6 roller rockers, "R" lifters, Underdrive Pulley, air foil, and SLP headers.
Posi 3.73 9 bolt rear end, BMR suspention components, 3200 Vigilante, and Transgo.
1990 Camaro RS
The 9 bolt is stronger than the 10 bolt but the 10 bolt can be beefed up to take a lot of abuse. I was running high 11's on a 10 bolt before finally switching to a ford 9".
The 10 bolt didn't get the 28 spline axles until 1990. 7 5/8" gears came around 86 or 87.
Athough it is a bit bigger, the 7 5/8" ring gear isn't much different from the 7 1/2". Both are interchangable on the same carrier.
Stephen's racing page
or check out the race car
87 IROC SuperPro race car
461 big block
Best ET on a time slip: 11.589
Best MPH on a time slip: 115.91
Best corrected ET: 11.114
Altitude corrected rear wheel HP: 457
Best 60 foot: 1.646
Member of the Calgary Drag Racing Association
461 big block
Best 60 foot: 1.646
Speeds8erM-1
Classic Engine Tech
Aug 21, 2002 01:06 PM
