Rearend
Old May 2, 2003 | 12:18 PM
  #16
AndrewC's Avatar
gears
check the stamped # on the crown gear
11.41 is 3.73 devide 11 into 41 to get your ratio
if you got 2.77 on the rear end now, your looking at a lot to replace them with others. So why would you want to? why not get a rear end with everything the way you want it.
good luck.
i got a 3.73 posi from the wrecker then found it needs to be shimmed and stuff when installed. i didnt get the pinion gear so the gear set is no good to me and it would all cost about $250 to have installed in my rear end.
mrwz28
Jul 8, 2015 09:11 PM
Flint78
Jun 21, 2015 01:28 PM
ddr698
Jan 9, 2015 10:05 AM
Speeds8erM-1
Classic Engine Tech
Aug 21, 2002 01:06 PM
kurshinsky
Jul 13, 2002 12:32 PM
