Rear tires are both wearing on the inside
Old Apr 22, 2003 | 02:48 PM
wildcard's Avatar
Question Rear tires are both wearing on the inside
Has anyone ever had their rear tires both wear out on the insides?? I have had some friends tell me that the rearend housing could be bent somehow, but I guess that I am looking for some other possibilities. If it is bent can it be fixed or would it be cheaper to buy a new rearend??
Thanks,
Ben
Old Apr 22, 2003 | 03:02 PM
Black6SpdTA's Avatar
never heard of that happenin before, rearend housing being bent sounds about right. couldnt be axles, wheels, or anything that turns so....man i dont know.
Old Apr 22, 2003 | 03:26 PM
caspergotaz28's Avatar
Lightbulb
Have you checked your rear wheel bearings? Jack the back tires off the ground, bear hug the whole tire, give it a tug and see if it is "solid" feeling or if there is some wobble in it.
Old Apr 22, 2003 | 05:48 PM
aklim's Avatar
If it isn't bearings, I'd go for bent axels next. Soulds like someone has been doing too many car jumps.
Old Apr 22, 2003 | 08:11 PM
stevem's Avatar
tire pressure
Old Apr 22, 2003 | 08:13 PM
Rice Killer87's Avatar
check the easy **** first,make sure the tire pressure isnt too high
Old Apr 22, 2003 | 08:49 PM
Lungz's Avatar
well, when you say inside, do you mean the middle of the tire or the part closest to the rear end housing? if it is the middle of the tire, check pressures, if it is the part towards the inside of the car, could be a few things i suppose, but bent axles/axle tubes could be
Old Apr 22, 2003 | 08:56 PM
wildcard's Avatar
I bought the rear end used and the only thing I had to do to it was install my brake brakets, and slide the axles in. I also changed the seals while I was at it. Anyway I have had the car 100mph+ so I don't think its a bent axle, because I'm sure I would have felt some type of vibration, or something would have come apart, especially at 5500rpms. However, I do have 5/16" wheel spacers on the back. I had to install them to clear the frame for my 275/50 15's. Could the wheel spacers be the problem?
Old Apr 23, 2003 | 08:06 PM
TheGreatJ's Avatar
If it were spacers or axles or anything that rotates then you would feel a MAJOR vibration in the rear of the car when moving. However, if you have a bent axle TUBE you wouldn't notice any vibes and you'd get the uneven wear. Did the rear come out of a wrecked car? Hitting a curb or other obstruction at speed can bend the axle tubes where they meet the diff housing. That's what I'd suspect.
If the housing is bent, your best bet would be to pick up a cheap rear, even one with blown gears, and put your gears/carrier/brakes/axles in it. You can find good housings for next to nothing...in fact I have a '91 10-bolt sitting in my storage building waiting for the first guy with $30 to come and pick it up. It's no use to me since I swapped in a 9-bolt.....
Old Apr 24, 2003 | 12:08 AM
wildcard's Avatar
Well, the rearend is a 8.5 out of a 1987 Grand National. There is what I thought to be minor damage to one of the brackets on the passenger side where the shock mount and is bent a little. If I were to find a 8.5 rearend with open axles would I still be able to transfer my posi unit to a rearend that originally had open axles? Posi GN rearends are very expensive, however I have seen some 8.5 rearends that have open axles that are pretty cheap.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
QuickSilver02
Apr 7, 2015 11:12 AM
Collector Car
Jan 5, 2015 10:58 AM
squarehead
Nov 21, 2014 08:02 PM
