bolting in new heads (how hard?)
Old Apr 22, 2003 | 08:06 AM
irocz8957's Avatar
im conisdering buying a set of tpi heads that have been reconditioned and have a 3 angle valve job they should just bolt right in but how hard is it to get to them and is there any suprises that i should be aware they could come up while working on it?
Thanks to all who reply!
Old Apr 22, 2003 | 10:39 AM
aklim's Avatar
Define reconditioned. What is the CC of the head, what kind of valves, etc. Steel or Aluminum and how much?
Do you have the torque pattern and a good torque wrench?
Old Apr 22, 2003 | 08:01 PM
camaronewbie's Avatar
Note that there is also a difference between heads and intake bolt patterns from pre-1986 and post 1987 - you have to modify the 4 intake bolts in the center of the intake if you put a pre-1986 head with a post-1987 intake, or visa versa.
Old Apr 23, 2003 | 07:45 AM
irocz8957's Avatar
thats cool so 87 and on i'll be ok?
Old Apr 23, 2003 | 09:02 PM
aklim's Avatar
Should be. I'd stay away from steel heads and go for a set of aftermarket ones. Lingenfelter makes some pretty good L98 heads for a decent price.
Old Apr 23, 2003 | 09:40 PM
brodyscamaro's Avatar
You can do it with the engine in the car, but I recommend pulling the motor if you have the equipment to do so
Old Apr 24, 2003 | 03:07 AM
Zepher's Avatar
I've done a head swap in the car, went from the stock LG4 heads on my 86 to a set of stock 87 TPI heads.
It's kinda hard to lift the 50lbs head while leaning over the car, but I'd rather do that than pull the motor. It's just my personal preference.
I changed heads and cam since I was going from this,
http://www.transamws6.com/pics/transam/Edelbrock.jpg
to this,
http://www.transamws6.com/pics/transam/engine.jpg
Tuned Port looks so much nicer than a carb.
My new setup looks even cooler than my TPI (except for the cool SLP Dual CAI I had)
http://www.transamws6.com/pics/04-2003/air_intake2.jpg
HectorM52
Jul 30, 2017 11:46 AM
maybe2fast
Mar 16, 2015 09:45 AM
Roadie
Feb 16, 2015 10:34 AM
rcajun86
Jan 30, 2015 01:56 PM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
