rear disc conversion
Old May 22, 2006 | 06:33 PM
white97T/A's Avatar
anyone using LS1 rear brakes on their 3rd gen? my buddy ask me to help him convert his rears to disc, and I found a good deal on some calipers and an e-brake set-up, just wondering what else I would need. I would assume some brake lines and backing plates to mount the calipers.
Old May 22, 2006 | 08:26 PM
respectirocz's Avatar
Re: rear disc conversion
the backing plates definately
also the e-brakle cables
the bolts to hold the backing plates to the axle flange
the calipers and the caliper brackets
the e-brake shoes
some nice new rotors and pads
new brake lines
Old May 22, 2006 | 08:38 PM
Camaro_Boy's Avatar
what about the master cylinder? does that not have to be exchanged to?
Old May 22, 2006 | 10:35 PM
ringo234's Avatar
How about a new proportioning valve?
I'm not sure the old one will work properly with rear disks.
Old May 23, 2006 | 06:16 AM
BlackRabbitZ28's Avatar
http://www.thirdgen.org/ls1reardisc
That'll tell you all.
Old May 23, 2006 | 10:10 AM
the master cylinder doesnt need to be changed
but if you put ls1 brakes up front and ls1 brakes in the back you are better off using the ls1 master cylinder
the proportioning valve will allow u the full benefit of rear disc brakes from rear drum brakes, because drum brakes do not use as much hydraulic pressure to actuate
its entirely possible to run ls1 rear discs with the stock drum proportioning valve
it just wont use the rear brakes as much as they could be used
Old May 27, 2006 | 11:22 PM
Kevin91Z's Avatar
3rd Gen Tech Moderator
What do you mean by convert his rears to discs? If he has drum brakes now he's going to need to do some fabricating. Drum brakes and disc brakes are not interchangeable.
Old May 28, 2006 | 05:07 PM
Camaro_Boy's Avatar
yes, tey are... you can buy a kit to change them over..
www.ecklerscamaro.com
you are correct as you need a bracket that comes in the package
Old May 28, 2006 | 05:42 PM
Dave89IROC's Avatar
um, there was a link posted that outlines everything needed, biggest thing is cutting 2 flanges, and drilling a few holes
Old May 29, 2006 | 01:06 PM
Kevin91Z's Avatar
When I said they're not interchangeable, I meant its not a direct bolt-on. I did say it required some fabricating...
Sorry for the confusion.
RUENUF
Mar 13, 2016 03:39 PM
HarleyZ28
Oct 5, 2015 06:23 AM
R@mpage
Apr 20, 2015 10:02 AM
