Radio wont pick up signal...
Old May 20, 2004 | 05:16 PM
91BigRedz28's Avatar
OK so I have the radio installed properly and everything. On my car, there is no antenna...looking under the hood, you can see that the front quarters are replacement, and I know that replacement quarters weren't drilled for the antenna. Where do I start looking, and how can I improve my radio reception without drilling into the body? I gotta listen to the Red Sox when I'm on the road, it's killing me when I hear "Pedro delivers..." and it cuts out. Thanks!
Old May 20, 2004 | 06:31 PM
IROC-T's Avatar
There used to be a invisible antenna that you could put in the car,it was a transparent tape that you stuck on the inside of the windsheild,they didn't work all that well for distance,but for local were fine. Try JC Whitney they might still carry them.
Old May 20, 2004 | 07:04 PM
Is it possible that they just hacked out my antenna and all the wires when they replaced the panel? I'd like to try to hook something up that doesn't sound quite as bootleg as a tape-antenna on my windshield...but if I have to, you can bet I will.
Old May 20, 2004 | 09:45 PM
Dave89IROC's Avatar
for local stations, a standard fixed mast antenna hidden inside (under)the center console works great
Old May 20, 2004 | 10:59 PM
TheGreatJ's Avatar
What Dave said. Just find one at a junkyard and hook up the wiring, and lay it across the dash under the dashpad. If you lay it the right way you can clear the defrost vents and the speakers and such. It'll pick up just fine.
Old May 21, 2004 | 02:24 PM
IROC-T's Avatar
It went around the outside edge of the glass next to the frame so you didn't see it. I used one on a car once and it was fine for about 40-50 miles as long as there were no mountains or really tall buildings.
Old May 21, 2004 | 10:45 PM
87DJP2001's Avatar
All third gen cars had the antenna mounted on the top of the front passenger side fender (No exceptions if a radio came with the car). And if you don't have one, my guess it is disconnected after the fender replacement. So no wonder you have such poor reception.
Old May 22, 2004 | 03:12 PM
IROC-T's Avatar
It could be a deletted item for a police(B4C) car ,or the 1LE package.
Old May 22, 2004 | 04:08 PM
87DJP2001's Avatar
You will note, Isaid if a radio came with the car.
ducttape1975
Jul 10, 2015 06:29 PM
4586
Apr 29, 2015 01:43 PM
ChrisFrez
Apr 12, 2015 12:40 PM
mattstrike
Mar 24, 2015 02:11 PM
