help!!!! Engine Wongt Start!
Old May 17, 2004 | 07:43 PM
85camaro350's Avatar
Ok, i have a 350 carbed engine and it caught a carb fire last august, just getttin everything together to make it run again and it cranks but wont turn over. I have a new distributor, carb, wiring harness and such and finally got it all together and it wont start. I am getting fuel in the carb at 6.5 psi, and spark from the distributor. yes i did put the distributor in the right way with TDC and all that. i am stumped, oh and i also have a electric fuel pump up by the engine.
Old May 17, 2004 | 07:58 PM
Rice Killer87's Avatar
since what u said hardly made sense,im guessing it turns over but doesnt start?
#1. thats too much fuel pressure for a carb,drop it drop to like 5.5 or 6 psi. what kinda carb. are u running?
#2. if i was u,i would bump the motor over w/ the #1 plug out untill u hear it hiss,then put the plug back in and see where the rotor is pointing (at the #1 plug wire).
Old May 17, 2004 | 08:01 PM
it is a brand new holley 600 vaccum secondary carb....i dont have a fuel regulator, just a gauge. yes it wont start. i will try and check where the rotor is but as i said i put it in at tdc pointing to number one. twice in fact....do you think it could be a internal problem???????
Old May 17, 2004 | 08:19 PM
angel71rs's Avatar
Did you pull the #1 plug as suggested above when you set it at TDC? If not, you could be 180 degrees off.
6.5#s is fine for a Holley. On a Qjet it would be a problem.
Any signs of flooding? A common problem on new carb installs is dirt getting in the bowl inlet needle(s). On a Holley you can pull the brass sight plugs on the passenger side of the fuel bowls. If after cranking the engine (presume you have a mechanical fuel pump) you pull the sight plugs and gas comes pouring out, you have dirt in the needles.
Old May 17, 2004 | 11:38 PM
Pneumatic_Tire's Avatar
Sounds like the distributor is off 180 degrees. I made the same mistake last weekend. Stumped me for a few hrs.
Old May 18, 2004 | 03:55 PM
ok, i put it at tdc and looked at the distributor rotor. Yes it was right on the 1 plug. so its not the distrbutor. when i pump it a coouple times it floods, but thats it, i dont know if thats what your talking about. its an electric fuel pump. PLEASE HELP!!!!!
Old May 18, 2004 | 06:15 PM
TheGreatJ's Avatar
TDC on the compression stroke or on the exhaust stroke?
Old May 18, 2004 | 06:32 PM
86305Z28's Avatar
u sure u hooked the spark plug wires up correctly on the distributor? id check the fire order n make sure
Old May 18, 2004 | 07:08 PM
so u have an electric fuel pump on a carbed car,w/ no regulator?? is the pump made for a carb and designed to push only 5-7 lbs or is it a fuel injection pump?
if its a fuel injection pump w/o a regulator that thing isnt gonna run w/ 40 psi of fuel being shoved into it lol.
P.S. - firing order is 1-8-4-3-6-5-7-2
i am sure of the firing order on the distributor.
also, i dont know what stroke i did it on, how can you tell and whats the difference?
Old May 18, 2004 | 07:10 PM
its for a carbed car....and when i read my fuel pressure it said 6.5 no regulator but oh well....i want to get a mechanical one and be done with it.
Old May 18, 2004 | 07:11 PM
what kind of distributor is in the car?
I think its my starter tell me what you think of this.
I tried starting it....tries to start for 1 second and the starter starts to click, every time i do it. so i went under the car and took a hammer to it a couple of times, it starts for a second and dies. look under car and starter is smoking a little. what about that?
Old May 18, 2004 | 07:13 PM
Post
brand new mallory HEI
turn the key on and see what the volt gauge reads.
when u turn it over,is it slow?
