Quick........timing question again.
Old Apr 30, 2003 | 07:22 AM
SNEAKY NEIL's Avatar
I just brought the car to the shop for some stuff and the timing. I told the guy that i wanted an 8 degree advance. He took it as I wanted 8 degrees total. Is he right? if not, what is the correct wording I should use to tell him what I really want. Thanks.
Old Apr 30, 2003 | 07:26 AM
irocz8957's Avatar
you would tell him 8*BTDC (before top dead center) that would mean that if you timing was at 6* you would have bumped it up 2*
Old Apr 30, 2003 | 07:29 AM
So everyone telling me I should have a 6-8 degree advance means that it should be 6-8 BTDC not that if it was 4 BTDC to start with, it should now be 12?
Old Apr 30, 2003 | 09:06 AM
aklim's Avatar
With the timing advance wire disconnected, it should be 6 deg BTDC. GM Motors are always 6 deg.
Old Apr 30, 2003 | 09:25 AM
Yeah, but I don't want the stock timing. I want to bump it up to the greatest performance that i can get and still run safe.
Old Apr 30, 2003 | 09:38 AM
jayman350's Avatar
no you do not want 8 degrees total timing, 8 degrees is the initial timing
total timing should be around 36 or so, depending on applications
Old Apr 30, 2003 | 09:45 AM
Holy crap I am confused! So what should I tell the guy at the shop I want in such a way that there will be no other way to understand it? (that is: I want to advance the timing to gain the most performance out of the motor).
Sorry for my ignorance.
Old Apr 30, 2003 | 01:51 PM
aklim's Avatar
Tell him to set the ignition timing to 6 deg with the advance removed unless you have a 3.1 engine
Victor Lamb
Aug 26, 2017 02:52 PM
maybe2fast
Mar 16, 2015 11:59 AM
carl.froehlich
Mar 13, 2015 12:38 AM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
