quick question...how many cca
Old Sep 1, 2003 | 03:13 PM
doug791's Avatar
I cant find in my owners manual how many cold cranking amps a 1990 5.7L would need to start. My battery is toast and im wondering if i could borrow the battery out of my moms 4.7L v8 dodge durango.
EDIT i checked and the ford windstar which is my backup car to drive has a battery that puts out 750 CCA which should be enough. Is there anything else i have to check to make sure itll be okay for my car.
Old Sep 1, 2003 | 04:34 PM
doug791's Avatar
come on this is a super simple question and i need an answer so i can take my baby out tonight. When picking a battery do i have to worry about anything other then how many cca's it has? if not 750 should be fine for my car.
Old Sep 1, 2003 | 05:07 PM
thezisking's Avatar
The battery will work fine as long as it's side mount.
Old Sep 1, 2003 | 05:12 PM
doug791's Avatar
by side mount do you just mean how the connectors attach? The battery is not side mount but i have the batter in the trunk and my connectors are the overhead style anyways so i think im cool.
Old Sep 1, 2003 | 05:57 PM
82355's Avatar
As a general rule of thumb you need twice the CCA of your CID so gor a 350 you need 700 CCA. You can get by with less in a pinch though, I wouldn't worry about it to much.
On a side note I always buy the biggest battery I can physically fit into the space its going. I like 875 to 1000 CCA, which could be considered overkill, but you really can't have to much.
Martin
Old Sep 1, 2003 | 07:06 PM
doug791's Avatar
sweetness i put the battery in and it works...it is running off 750 cca's and it just has to get me by for a day or 2. Thx for the help guys.
IndyZman
Oct 22, 2015 02:17 PM
WobblySausage
Oct 7, 2015 02:44 PM
68camaroboltz
Oct 5, 2015 11:56 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
NewsBot
Sep 14, 2015 09:20 AM
