Questions about DFI...
OK, I have some questions about DFI, specifically GEN 6-7, and FAST.
I am pretty sure you can buy either system with or without an intake manifold. Anybody know of website with pricing?
How do these systems compare to a Holley Commander? Accell and FAST are direct port fuel injection (8 injectors) right? The Holley Commander is a throttle body style injection, or is it?
Are there any other fuel injection systems out there I should consider for a 400+ cube small block chevy?
Electromotive makes one, the TEC-3.
www.electromotive-inc.com
Electromotive is the best company out there. You can manage and change the idle of your vehicle very easy and is said to even make heavy cammed engine get vacuum and retain good idle, and with a push of a key go back to raped ape.... Plus you won't need a MSD, or a window switch, or nos retards, or boost retards.. This thing does it all! within nano seconds the 60 tooth crank trigger is supposed to boast the best timing out there
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
