putting the iroc-z sideways
Old Aug 8, 2003 | 09:33 PM
lordmetalz28's Avatar
i rember 2 years ago i drove my friends 3.1 v6 camaro and i hit the gas hard and the rear kicked out a bit. i also did the same on my bosses 87 iroc-z with a 305. i have the exact same car with probably the 3.42 exact same gears and i cant get it sideways when i punch it. i get it sideways around a turn and when i hit around 3 grand from a dead stop my tires break loose and go nuts for a bit. but i cant get it to kick out. does posi track play a role in this because the v6 had no posi and when i burned out i left one tire mark . on mine i leave to nice even flush tire marks
Old Aug 8, 2003 | 09:41 PM
Black6SpdTA's Avatar
Posi make's it a lot easier, no doubt. Here's my procedure to kicking the 'ol rear out:
Pull up to stop sign, traffic light, etc
Start going forward kind of slowly
As floor the throttle, turn the wheel hard!
Straighten up
Repeat as necessary
Works every time. Oh yeah, I've got an open rear. It works best going to the left, when I go right it usually only works if there's some water on the ground.
-Rippin
Old Aug 8, 2003 | 09:45 PM
ill have to practice this in an open parking lot so i dont do something stupid and crash
Old Aug 8, 2003 | 11:15 PM
slow_roc's Avatar
befoer i did the posi switch over that *** end would always get lose like no other but since the i put the posi in i barely breaks them loose dead get, on turns it might slide out a lil notihng to crazy
Old Aug 9, 2003 | 02:03 AM
Blownyellow's Avatar
Straighten up
Repeat as necessary
-Rippin
LOL, I am sorry man but that particular method of fish tailing usually ends up looking seriously geeky. It seems that the only people who think it looks cool cranking the wheel to try and force a slide, are the people who are doing it. I just looks down right dumb from the outside.
I would suggest a nice tight posi unit, or if you already have one, get the clutch packs replaced. If you have a healthy posi, your car should almost instantly kick sideways when dropping a standard.
Old Aug 9, 2003 | 09:38 AM
Come on man!
#1 - I try to do it when no one is around to be safe so what it looks like doesn't mean anything to me.
#2 - I don't have a posi yet. Is there any other way to do it with an open rear and like 150rwhp?
Old Aug 9, 2003 | 02:07 PM
AutoRoc's Avatar
Posi plays a huge role. If both tires don't spin, then you need enough momentum on the rearend to actually SLIDE the tires over the pavement. It's much easier when both tires are already spinning.
Old Aug 9, 2003 | 05:16 PM
Zepher's Avatar
http://www.transamws6.com/video/ZepherWS6.mpg
Old Aug 9, 2003 | 05:29 PM
yeah thats what mine does it kicks out a bit on take off but in like gear i could get the others to kick out but mine i cant. what im saying is when i moving i cant from a start jus tlike zepher i can i do the identical thing zepher did and my car also slides right on a burnout to. oh well must be the posi
Old Aug 9, 2003 | 05:40 PM
Zepher's Avatar
I could kick it out from a 25mph roll with the TPI setup I had.
I was going to lite um up bigtime in that vid but there was a truck behind me. Dude gave me a dirty look when I was turning around.
Having higher numbered gears helps out too.
Old Aug 9, 2003 | 05:53 PM
DrDUKE's Avatar
Mine dose it at WOT anywhere from a stop up to 25. With any amount of rain it will spin 180 quicker than you can blink.
It must be your posi.
Old Aug 9, 2003 | 09:56 PM
Is your motor just a stock L98 or do you have any mods? I'm just curious.
Old Aug 9, 2003 | 10:44 PM
DrDUKE's Avatar
Nope stcok TPI . Tuned very well.
Old Aug 10, 2003 | 02:13 AM
12Second3rdgen's Avatar
It's funny that some people wish their cars would get sideways. I wish i could get on it in first on the street without going sideways .
Old Aug 10, 2003 | 10:32 AM
i wish i never bought those power pulleys but every bit helps i hear
rideordie
Nov 5, 2019 04:52 PM
blue89iroc
Jul 26, 2002 04:56 PM
blue89iroc
Jul 18, 2002 04:41 PM
blue89iroc
Jul 18, 2002 03:35 PM
