proper valve lash?
Old Jan 6, 2003 | 11:25 PM
Osmosis's Avatar
proper valve lash?
What is the lash supposed to be set for the 91 l98 heads? I forgot if it is 1/2 or 3/4 lash. I prefer not to lash them with the engine running.
Old Jan 6, 2003 | 11:42 PM
Osmosis's Avatar
I forgot to add, the chilton book says once you have the valve at zero lash, to put 1 1/2 turns on teh rocker nut. That seems too tight!?
Old Jan 7, 2003 | 02:28 PM
Chuck!'s Avatar
I went 3/4ths more when it stopped chattering.
Old Jan 7, 2003 | 08:02 PM
TheGreatJ's Avatar
1.5 turns is too tight IMO...I use 3/4 turn past where you get drag on the pushrod.
Old Jan 8, 2003 | 09:43 AM
aklim's Avatar
I tightened it till the pushrod started dragging and then 3/4 turn and lock it there.
Old Jan 8, 2003 | 10:08 AM
Osmosis's Avatar
I miss read the chiltons book. It is 1 1/2 for the v6, the v8 is one full turn past zero lash. I have always gone 1/2 lash. I just wanted to make sure. Thanks for the help!
MadMav
Jun 15, 2015 09:51 PM
dylan1303
May 22, 2015 12:24 PM
FredM
Apr 10, 2015 02:56 PM
GA93FORMULA
Jul 24, 2002 11:38 PM
