posi question
Old Mar 20, 2008 | 12:01 PM
lordmetalz28's Avatar
posi question
well i had my new eaton posi installed in 2004 and the manufacter said it needed mineral based oil,, my mechanic said just run synthetic with posi fluid in there so i did,, every year i drop the oil and theres some metal on my plug magnet which made me decide this year to run regular rear fluid with posi additive,, now since ive been runnin sythnetic for 4 years is this going to cause a mixing problem with the new non syntetic oil?
Old Mar 20, 2008 | 03:16 PM
Z28SORR's Avatar
NO! Small amounts of metal (shavings) are completely normal.
Old Mar 21, 2008 | 05:53 PM
what about mixing the synthetic and non synthetic fluids is that a problem?
Old Mar 21, 2008 | 08:50 PM
Z28SORR's Avatar
No. Synthetic oil is still OIL!! Just "purer", i.e. more precisely manufactured.
Old Mar 21, 2008 | 10:40 PM
HottestZ28's Avatar
I though sythetic was "man-made" stock. but def can be wrong
if they state only mineral oil i would do exactly what they spec. There is a reason they state no sythetic.
Old Mar 22, 2008 | 07:17 AM
DrummerDad's Avatar
I dont know much about the Eaton, but Ill share what happened to me:
I had an AWD Astro van, with a clutched front posi differential, similar to an auburn. I dont know what they are called from the factory. Anyway, the seal went out, so I decided to change it myself. All went well, untill I went to put fluid in. I asked the guy at the counter of Auto-Zone what the factory recommends. He said 90 weight gear oil, but that since I was changing it, use synthetic. So I did.
To make a long story short, the synthetic fluid actually "glued" the clutches together. I took it to the dealership, the only people who would work on it, and it had locked the front differential, acting like a spool. It had busted the mounts, and the housing, and cost me over $4k to fix, with used parts. If it has any clutches, DO NOT use synthetic fluid. Thats from a GM certified master mechanic, so take it for what its worth. And I no longer deal with Auto Zone.
Old Mar 22, 2008 | 09:50 AM
thanks for the input,, but theres no way synthetic oil glued gears,, dude you musta had a screwed up bearing or something,, but besides the point i been runnin synthetic oil in the rear for 4 YEARS now and no problems,, im just gonna leave it be now,, IF IT AINT BROKE DONT FIX IT YA KNOW
Old Mar 22, 2008 | 03:10 PM
Z28SORR's Avatar
"man-made" and "manufactured" mean the same thing. It's still has the exact same hydrocarbon compones as petroleum oil.
Old Mar 22, 2008 | 03:30 PM
Z28SORR's Avatar
It will make absolutely no difference to your Eaton Posi whether you use syn. or petroleum based oil as long as you use the GM posi additive. Go look at the Eaton web site! The reason Auburn recommends using petroleum oil is because the unit was never been "certified" for use with syn.
Old Mar 22, 2008 | 04:54 PM
thanks z28sorr im just gonna continue to run the syn in that case
QuickSilver02
Apr 7, 2015 11:12 AM
blac94Z
29
Mar 25, 2015 04:21 PM
TitoPR221
Jan 29, 2015 08:00 PM
ddr698
Jan 9, 2015 10:05 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
