ported maf didnt work?
Old Apr 11, 2004 | 09:18 PM
kevin 2.8's Avatar
i had a spare maf kicking around used but never used by me, so i was bored and went at it with the dremel. i cut out the screen, the retainer that held the screen in and the lip and tabs that held the retainter in.
threw it on my car and started it up it had a really rough idle wanted to stall and had a huge hesitation.
is this maf fubar or is there somthing i can do. i only ran it for a minute but i didnt see any codes come up for it. maybe it was bad when i got it?
ill try it again if i get another spare maf... i dont want to hack up the original one that works fine.
Old Apr 12, 2004 | 12:10 AM
aklim's Avatar
Well, have you ever tested the spare maf before you ground it? You might not have got a unit that is calibrated for your car. In any case, after grinding it, you might have to drive the car for a bit so the ECM gets used to the new calibration.
Old Apr 12, 2004 | 01:59 AM
kevin 2.8's Avatar
ok ill try that tomorow
Old Apr 12, 2004 | 10:42 AM
aklim's Avatar
You can try erasing the settings in the ECM by disconecting the battery for a bit and then let it see if it can set itself. However, it is too late for you to verify that the MAF works because that is something you should have installed, unmolested for a week to make sure. Now all you can do is check part numbers and make sure that they are for the same application.
Old Apr 12, 2004 | 05:50 PM
kevin 2.8's Avatar
reset ecu, put it in, started to idle better still hesitating. took it for a drive and the engine light came on.
its bad and will be my new coffee mug soon. ill find another one and try again
Old Apr 12, 2004 | 09:24 PM
aklim's Avatar
Well, maybe that porting threw the calibration off or maybe it was never good in the first place. If you are going to do this, make sure you install it first and run it so we are working with a known good one.
Old Apr 12, 2004 | 09:26 PM
aklim's Avatar
What does the code come up as? If you had a scanner, you might be able to tell what the reading is and have a better idea of what it is doing. Maybe you broke the filaments. Also, are you sure that is the correct MAF for that application?
Old Apr 12, 2004 | 09:29 PM
kevin 2.8's Avatar
yeah it was off an 86 with the 2.8
i have a scanner, the code is still stored. ill plug it in tomorrow just to make sure it was
shouldnt have broke the filiments, they are suspended in the middle and i was real careful with my steel carbide bit.
this maf is going to be one sweeeet coffee mug though
parkers Z28
Mar 11, 2016 08:14 PM
oldschool
Feb 9, 2016 09:21 PM
Roadie
Feb 16, 2015 10:34 AM
RedLineRev
Jan 23, 2003 03:51 PM
SLIMJIM
Jan 7, 2003 11:06 AM
