Pop-up headlight sticking
Old Aug 20, 2002 | 09:10 AM
SNEAKY NEIL's Avatar
Post Pop-up headlight sticking
On the 90' Formula, the headlight appears to be sticking. When the lights are turned on, one goes up fine but the other goes up only halfway. If I turn them on and off a few times, it comes up. Does the light mechanism need to be lubed or is this the start of the motor going bad? Thanks.
Old Aug 20, 2002 | 11:25 AM
aklim's Avatar
Post
Never lubed mine before. Sounds like the start of a need for a new motor. That is, unless you have tried the obvious. Greasing the joints. What you need is someone to turn it on while you listen to the motor with a stethoscope. If you don't hear a smooth running motor, time to get a new one.
SEOJustin
Sep 24, 2015 04:39 PM
DarksideII
Parts Wanted
Sep 23, 2015 11:14 PM
Greg88
Sep 20, 2015 07:14 PM
jackpawt883
Sep 10, 2015 08:53 PM
Aug 17, 2015 09:50 AM
