oil on spark plugs
Old Apr 10, 2006 | 12:35 AM
Camaro_Boy's Avatar
oil on spark plugs
so im having problems getitng my 350 from this freind of mine. so ive decided to fix this motor for now to get it off to the paint shop.. its a 86 camaro 305 v8. i can run the car for about a hour or so.. if that.. and if i shut it off.. it wont start back up cause the spark plugs are so gummed up with oil and gas. what is the most likly cause of the spark plugs being gummed up? piston rings i hear is a good bet.. just wnated to see what problems you guys have with the 305.. thanks alot. and for whatever you reply what is the average cost of the item??i have the book and am going to start to rip apart the motor tommorrow? thanks again
douglas
Old Apr 10, 2006 | 12:43 PM
king1138's Avatar
Re: oil on spark plugs
sounds to me like you might be getting gas in your oil. this will cause the oil to be more viscuous, or thinner, and it will leak into the combustion chamber via the piston rings and valve stem seals, which would gum the plugs. to check this, pull your dipstick and hold a lighter up to the oil on it for a few seconds. if it flairs up, gas in the oil. if not, you have a different problem. the cause of gas in the oil is usually a bad pcv valve.
Old Apr 11, 2006 | 11:19 PM
Camaro_Boy's Avatar
tried that.. nothing.. no gas at all in the oil.. i hear from alot of other post i read that the 305;s are worth being rebuilt.. and i understan but as i said its getting hard for me to get my freinds becuase hes ****ing busy... but yes thanks again for all the help.. i think i might just tear the motor apart and see if i can see what it is... thanks again guys.. aweomse!
douglas
Old Apr 12, 2006 | 02:51 PM
85_305's Avatar
It may very well be valve stem seals but I'm not sure
Old Apr 12, 2006 | 02:57 PM
Jazsun's Avatar
Ill bet money it is valve stem seals. When mine went on my lt1 there was oil clumps all over the spark plug(s) which were effected. Replace the seals and clean the plugs and see if it continues.
Old Apr 12, 2006 | 10:03 PM
Camaro_Boy's Avatar
awesome!, thanks... thought this would get you... i managed to talk to that guy about the 350 again.. friday i maybe be going to get it thanks so much tho!
if i must fix it i will repost ehhe thanks!
Douglas
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
Dark Zeiro
Mar 11, 2015 07:15 AM
jasonduaine
Mar 7, 2015 09:44 AM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
