2.8 mfi to 5.7 tpi conversion question
Old Apr 9, 2006 | 08:05 PM
Black305RS's Avatar
has anyone ever done this and if so id like to know what parts from the 2.8 can be reused and what i need to get off a tunedport car since there are 2 available in the junkyard for parting, so i can sucessfully do this.. besides computer, wiring harness ect.
Old Apr 9, 2006 | 08:53 PM
Pneumatic_Tire's Avatar
Re: 2.8 mfi to 5.7 tpi conversion question
I've never done this but you will need probably the whole wiring harness, ecm. What kind of trans you got? If you got a standard you will need a different trans too cause the 6 cylinder version differes from the v8 version. If you have a 700r4 though, i am pretty sure it will work without much of a problem. I think if you go over to www.thridgen.com they got a whole step by step article on how to do it.
Old Apr 9, 2006 | 09:48 PM
Kevin91Z's Avatar
3rd Gen Tech Moderator
No, the V6 transmissions, both the 700R4 and the T5, have a different bellhousing bolt pattern and will not bolt up to the V8 engine. Basically you need everything from the V8 car. Radiator, front engine accessories, engine, lines, wiring harness, computer, transmission, cooler lines, tranny mount, and driveshaft. You might as well grab the front and rear sway bars and shocks and springs, too, as the V6 stuff is smaller and softer.
Old Apr 9, 2006 | 10:14 PM
Black305RS's Avatar
if i need a different trans than ill ahve to scrap the idea cause that would be too much. its really too bad iff thats the case, cause i was looking forward to having the 342 final drive gear that the v6 has on an l98 motor. anyway not that i dont believe you Kevin91Z but can anyone else confirm that the v6 700 has a different bolt patern than the v8 700.
Old Apr 10, 2006 | 10:46 AM
patstoy's Avatar
v6 cars have a 60 degree bell housing. v8 cars have a 90 degree. Information given by Kevin is all correct.
Old Apr 10, 2006 | 11:55 AM
SmokingSS's Avatar
motor mounts would have to be changed too, or a v8 k member.
Old Apr 10, 2006 | 11:56 AM
Black305RS's Avatar
thnaks guys looks like ill have to scrap the idea.
Old Apr 10, 2006 | 05:18 PM
sorry man, time to shine it all up real pretty and sell it towards the purchase of a tpi v3 z28 or Iroc.
Old Apr 10, 2006 | 07:59 PM
Black305RS's Avatar
im gonna put a mild cam into it to boost its power to that of the LO3 motor so i can hopefully get 1500 for it.
than yes ill go find me an iroc even if i have to drive to another state. i found a good page that fbody sellers post on.
Old Apr 11, 2006 | 11:51 AM
BlackRabbitZ28's Avatar
Can you link that page? I'm putting mine up for sale.
Old Apr 11, 2006 | 04:54 PM
Black305RS's Avatar
how much blackrabbit
and heres the site http://www.fbody.com/
Old Apr 12, 2006 | 01:24 AM
Faded's Avatar
Incorrect information. The V6 T5 will bolt up to a V8. IIRC you need the bellhousing from a V8 T5 though. And you have to get a clutch for an S10. As said before, checkout thirdgen.org, lots of info on this.
Old Apr 12, 2006 | 01:30 AM
Faded's Avatar
Also, the driveshafts are interchangable as well.
Old Apr 12, 2006 | 10:32 PM
Kevin91Z's Avatar
Its not incorrect info, just practical info. He wants to use his V6 stuff and I said it wasnt possible. The S10 clutch you talk about is the same one as for a V6 thirdgen. And do you think a V6 clutch will be a high-performance model for a V8? I doubt it.
I forgot about the motor mounts, yes those need to be changed, too. Basically, its not a worthwhile swap unless you're getting all the parts for free and you know how to do the swap yourself. You would spend less money selling your V6 car and buying a V8 car.
Old Apr 13, 2006 | 12:14 AM
Faded's Avatar
It's not a thirdgen V6 clutch. The one I'm talking about is larger. Anyway, it's true it's not a worthwhile swap. A V8 tears V8 T5's apart, and with the lower gears in the V6 version it won't last long. Just saying it's possible, as long as you drive it nice.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Jonnybegood
Parts Wanted
Feb 10, 2015 07:50 AM
kennyirocz
Feb 7, 2015 11:41 PM
Queens94z28
Dec 20, 2014 09:11 PM
