Oil keeps leaking from oil filter
Old Apr 17, 2004 | 12:56 AM
DanTheIROCMan's Avatar
I swear I have put in about 3 new oil filters since I had my reman long block put in a couple of years ago and everytime, they eventually start leaking. Is it possible that the surface that the oil filter mates with is warped on the block causing this continuing leakage?? I tighten the filter up properly by dipping my finger in oil and rubbing it on the oil filter gasket and then hand tighten it and then turn it one turn after that. Any ideas? I really hope the surface isn't warped cause If that's the case, I don't think there's much I can do cause I know I can't just put gasket sealant in there, or can I??
Old Apr 17, 2004 | 01:06 AM
aklim's Avatar
No you had best not put sealant there. I doubt that area is warped. Next time you have the filter off, check if there is an old gasket there. Also try another brand of filter. The most important thing to do is to make sure that is where the oil is coming from. Clean the area extremely well and add some dye into the oil and use a blacklight every other day to check.
Old Apr 17, 2004 | 03:07 PM
1fastformula's Avatar
Do you have an oil cooler on there????? I took my stocker off and never looked back!!! Just use synthetic and you can say good bye to the oil cooler leak blues.
Later
Old Apr 17, 2004 | 06:56 PM
ThirdgenTa's Avatar
It could be the oil cooler or there could be something obstructing the gasket. Next time you take it off wipe a clean cloth along where the gasket sits. Make sure there is no leak point higher then that too. I know on my old T/A it was always leaking off the filter. I did make suer there wasn't a gasket and eventually I wiped the filter surface clean and it stopped leaking.
PCLZ28
Dec 24, 2015 05:19 PM
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
95z_28_camaro_4_Ivan
May 8, 2015 09:56 AM
SpeedJunkee
Apr 23, 2015 09:51 AM
NorthPoleDev
Dec 31, 2014 03:20 PM
