New best with my TPI.
I ran a 13.581@105mph (2.217 60ft
I need a convertor badly. Torque is way down with the cam.
This is a stock runnered TPI car with ported stock heads, headers, and a mismatched cam (282XE on a 110 LSA). I plan on going to a SR eventually so that is why the cam was chosen.
I picked up 6mph from stock so I am pretty happy with it. Oh BTW the density altitude was 2800.
Botch
)I need a convertor badly. Torque is way down with the cam.
Botch
Originally posted by teke184
wow, for the altitude and the 60ft i'd be pretty happy.
get some good dragradials and see what she'll do.
you'll definatly startle some LT1s and even a few LS1s
Thanks for the compliment,
Botch
Originally posted by robvas
What RPMs does it stop pulling at?
282XE, 230/236, .510/5.20, 110 deg
That the right cam?
What times did you run before the cam?
That the right cam?
2. Yes, but I am running 1.6 rockers so lift is .544, .556
3. I really don't have an absolute "apples to apples" comparison. I did a lot of mods to the car at the same time. It ran good in stock form, in fact I only went .004 faster after all the mods. I have a little work left to get it dialed in. I think I will put a SY3500 convertor in it next.
How are you getting the car to run up to 6100 rpm? I know your setup is not quite stock, but that top end should be quite restrictive. Are you holding it in second longer or what? Just curious, I have never heard of a stock runner setup holding to those kinds of rpms and still pulling
Will
Will
My stock base is heavily ported and siamesed 2.5". The upper plenum is ported heavily as well. I am holding the tranny and manually shifting it until I change the governor springs in the tranny.
Dirt Reynolds- I really can't tell for sure on HP from the siamesing as I ported the heads, added long tube headers, and did the cam at the same time. I know it pulls higher up more than it would be capable of without siamesing. I am still limited by the stock runners and the small runners in the intake near the head. I actually considered filling the injector boss area with epoxy and enlarging them, but decided against it. I am going to go to a S/R soon and will sell this intake then. I am real pleased with the MPH. I am hoping the thing will run 1 or 2 more with a better D/A.
Botch
Botch
The headers were not too bad to put on. I had to get a different starter though. I also had to move the knock sensor from the passenger side to the driver's side of the motor. I don't have a webpage. Thank you and I am pleased with the LTR setup also. I really think it will go nuts with a better intake though. I am thinking of putting a convertor in it and seeing if I can get a 12 out of the LTR setup.
Botch
Botch
Looks to me like you really thought through all your mods. I bet you are right - a converter swap (maybe a Yank?) would see you hit the 12's with traction. I wonder if you would be even quicker with a bit less cam?
Dirt- Thanks, I think it would be faster now with a smaller cam, but I am going to put a HSR on it eventually and wanted to plan for that. I am planning on trying to get into the 12s with a converter then swapping intakes, and then putting in a 150 shot of nitrous. I have forged pistons in it so I should be good there.
