Need To Pass E-check!
Old Feb 8, 2005 | 02:44 PM
JSkeet's Avatar
im not feeling very confident in my car passing this time around... i ran a scan on the system and it came back w/ a faulty O2 (among a few other things) so... here's my cry for help!!
I got temp. tags until I can register it here in OHIO (im a new resident) and need to get it inspected and e-checked in the next month.
Any tricks I can pull to get the car to pass?! (inexpensive tricks...)
info on the car: '84 LG4 w/ Flowmaster catback and a capped cutout. running stock cat. and dual exit flowmaster muffler. car has basically been sitting the past 3 months
Old Feb 8, 2005 | 05:44 PM
Camaro_Boy's Avatar
Re: Need To Pass E-check!
im from toronto ontario, i havea guy that just passes the car either way.. im not sure of what u have to pass.. but we have certification as well as a etest... emissions...
just gotta pay a little extra... someone will help u out
Regards
Douglas
Old Feb 8, 2005 | 10:59 PM
JSkeet's Avatar
i think i have to pass an inspection (under the hood, they also look at the exhaust) and an emmissions test where they check the level of HC, CO, and CO2 your exhaust is putting out
idk if having a cutout will affect it at all, its capped, i hope they pass me on it...
Old Feb 9, 2005 | 06:40 AM
87DJP2001's Avatar
In the Cleveland area E-Check the following is looked at:
1) visual for the Cat
2) Tail Pipe check for what you stated. Sometimes on the rollers and other depending on the car tail pipe probe only.
3) Gas cap presure test.
That it for your $19.50 cash every two yrs. Just make sure the car is warmed up to normal temperature.
They don't pop the Hood or look for any performance items.
Unless your car is dog with no Emission controls it should pass.
Old Feb 9, 2005 | 02:06 PM
respectirocz's Avatar
just so you know, emissions checks levels of HC CO and NOx, not CO2
Old Feb 9, 2005 | 03:00 PM
JSkeet's Avatar
I checked my old papers from Kentucky Emissions and the paper says clearly CO2.
so i shouldnt run higher grade gas or put that emissions pass stuff in the tank from auto zone??
it passed sept. '02 w/ flying colors but damn... that was a while ago!!
Old Feb 9, 2005 | 06:36 PM
Wacky Tower's Avatar
You should be able to pass as long as your car is running good. Mine passed with the timing backed off a little, AIR stuff put back on(just for the test) and a stock replacement cat(my other one is hollowed out). With my way-out of tune 406.
Old Feb 9, 2005 | 07:21 PM
JSkeet's Avatar
i know in '02 when it was last tested I had owned the car about 6 months and there were no records of the last tune up... from may of '02 until just recently nov. '04 there were no tune ups done on the car.
I changed plugs/wires in nov. '04. I hope that gives me the advantage against this STUPID law.
PS: I cut the air pump belt last summer and havent put a new one on yet, would you guys advise me to do that before I even try to test?
Old Feb 9, 2005 | 07:26 PM
Yes, It really helps
Old Feb 10, 2005 | 11:47 AM
JSkeet's Avatar
well, im off to AutoZone to buy a new belt then.. thanks!
Old Feb 11, 2005 | 05:10 PM
IROC-T's Avatar
I would replace that O2 sensor also(use AC type not a Bosh)and change your oil before the test,this will help.
David Dempsey
Mar 12, 2016 12:42 AM
4586
Sep 6, 2015 03:10 PM
Steve69SS396
Track Kill Stories
Aug 17, 2015 08:48 PM
karpetcm
Aug 14, 2015 03:02 PM
Cam's maro
Aug 11, 2015 07:45 AM
