Need opinions ASAP!!
Old Nov 11, 2003 | 07:51 PM
95redvert's Avatar
I have a opportunity to buy a Moser 12 bolt that is from a wrote off car. Unfortunately the car is a 98 WS6 Formula, and I am 99% certain that it will not fit my 88 GTA. Right?? So I am wondering if you can get rear ends cut to fit? Has anyone ever heard of this. I need to know ASAP as the rear won't last long at the scrap yard.
Old Nov 12, 2003 | 01:23 AM
kevin 2.8's Avatar
taken from http://web.camaross.com/forums/showt...=4th+rear+swap
jayman350
Advanced Member
you can swap in a 4th gen rearend and all you have to do is change the proportioning valve so that the disc brakes will work
I did this about 2 months ago, i love having posi, disc brakes are SOOOOO much better than drums, and the rear ends are very available and came w/ a bunch of different gears
you may want to private msg him
__________________
Old Nov 12, 2003 | 02:24 AM
aklim's Avatar
Isn't the length a little different between 3rd and 4th?
Old Nov 12, 2003 | 02:36 AM
kevin 2.8's Avatar
i think ive read here that the distance wheel to wheel is like an inch longer but better do a search to make sure. should not make that much of a prob wider is better? </end cliche>
Old Nov 12, 2003 | 10:21 PM
Dave89IROC's Avatar
a fourth gen rear is 4 inches wider, i.e., 2 inches per side, you can then fit fourth gen/vette wheels using only front spacers though, it will bolt right in though
Ks0209
Oct 1, 2015 07:32 AM
drt
Sep 27, 2015 04:39 PM
SEOJustin
Sep 24, 2015 04:39 PM
Devinfoote87
Sep 4, 2015 05:52 PM
