Need help Identifying camel hump heads
Old Mar 16, 2006 | 11:06 PM
SpunBearing's Avatar
I think that is what is on my camaro but I'm unsure.
looking on the end of the head it has a small emblem looking thing that looks like: Something like this ======> |v|, Is this a camel hump or double hump head?
I'll try and get pics with my camera if I can get it in there.
Old Mar 16, 2006 | 11:35 PM
89_Irocz's Avatar
Re: Need help Identifying camel hump heads
http://cgi.ebay.com/ebaymotors/Chevy...46592464QQrdZ1
Old Mar 17, 2006 | 06:49 AM
I have seen those literally, I was looking on google and saw those exact heads last night.
Instead of beaing rounded humps mine are like 2 points.
Old Mar 17, 2006 | 07:08 PM
82355's Avatar
Then they are not camel backs, what is the casting number?
Martin
Old Mar 17, 2006 | 07:23 PM
xpndbl3's Avatar
i think you're looking at the humps that almost every 416 or 081 casting has on the front. you need to pull a valve cover to figure out what you have exactly.
Old Mar 17, 2006 | 08:43 PM
Stephen 87 IROC's Avatar
The double triangle is not camel heads. They're probably 330545, 3973493 or 3998993 castings. The 993 casting is a good casting. Small 1.94/1.50 valves but can easily have 2.02/1.6 installed. 74cc chambers. Good heavy casting with little chance of having cracks. These are considered intermediate heads.
Check to see if there are any steam holes. Two of these castings were available on 400's.
Old Mar 18, 2006 | 03:25 PM
Found out after pulling the valve covers and checking the numbers, they are the stock 305 H.O. heads from 84. Oh well, the guy lied about everything else on the car.
I think I got some 993's on the 383, I checked those also friday and beleave that was the number. That's good to know, I was gonna pull those off if they weren't good.
The guy also said it has 2.02 valves but I will find out later if I yank the engine out. I bought a hard top car for the 383, think i'm just gonna sell the 84 t-top car I have now.
Old Mar 18, 2006 | 07:12 PM
If the engine is a 305 then I doubt it has 2.02 valves. The cylinders are just not wide enough for 2.02/1.60 valves without notches cut in the deck for the valves to clear.
Victor Lamb
Aug 26, 2017 02:52 PM
Roadie
Feb 16, 2015 10:34 AM
NewsBot
Jan 29, 2015 07:10 PM
NewsBot
Dec 28, 2014 06:20 PM
Sixer-Bird
34
Aug 31, 2002 12:59 PM
