k&n filter for 92 Z28
Old Mar 8, 2006 | 08:17 PM
92brZ's Avatar
i'm looking for a k&n filter for my 5.7 liter 350 in my 92 camaro z28.i was lookin for the oval type that would mount right onto the throttle body, eliminating the duct type intake and filters. anyone know of any ? i think there is some out there, jus not sure where. ? ? thanks again everyone
Old Mar 8, 2006 | 09:07 PM
Tremo's Avatar
Re: k&n filter for 92 Z28
Your intake air will be cooler if you grab it from in front of the radiator, as opposed to hot engine compartment air. You have no flow sensor in front of the TB?
Old Mar 8, 2006 | 09:29 PM
92brZ's Avatar
i acutally thought about the hot air factor, if i used the open type of filter straight onto the throttle body but i was jus lookin to get more air. i recently put full mac exhaust and headers on my car . so i was lokin for more air . any suggestions? if i have the right idea
Old Mar 9, 2006 | 01:54 PM
Tremo's Avatar
I just kept the stock cold air plumbing on mine, and threw in a set of K&N filters in the stock locations. Works just fine.
You have done the throttle body water bypass, haven't you?
Old Mar 9, 2006 | 01:59 PM
staleyracing's Avatar
Hey im not sure if ill be much help but I just put a cold air kit on my Z28 and I have the stock box and 2 K&N filters you can have for a nice penny
Old Mar 10, 2006 | 12:29 AM
Kevin91Z's Avatar
3rd Gen Tech Moderator
No, 85-89 TPI setups use a MAF sensor in front of the throttle body to measure the incoming air, while the 90-92 TPI have a MAP sensor mounted on the plenum to measure the vacuum, or engine load. Its a straight shot from the filters to the throttle body.
Old Mar 11, 2006 | 02:08 AM
Castro's Avatar
Camaro's run so hot I would say avoid grabbing the air from the inside of the engine compartment. Its an oven in there...and as usual hot air isn't good for the car.
Old Mar 18, 2006 | 07:56 PM
MyName's Avatar
I bought one from Jeg's years ago, and I think they still have it. Look under their TPI/LTI/LSx section.
I took it off after someone told me it was bad for the motor/performance because of the heat and all, but I never noticed it one way or the other. I do recall it making a loud hissing/whistle sound (no, not an air leak) at certain RPM's that I thought sounded pretty cool.
PCLZ28
Dec 24, 2015 05:19 PM
Deadbolt24
Jan 19, 2015 01:29 PM
30thZ4C
Dec 26, 2014 05:09 PM
Dec 1, 2014 08:08 AM
Jul 4, 2005 05:00 PM
