My car won't start
Old Apr 24, 2003 | 12:33 PM
firebirdjosh's Avatar
My car won't start
My 1989 firebird ran great yesterday. Today I go to my car and start playing with a remote starter I bought a few weeks ago and I install it the way it says to. I go to start the car with the remote a few times and nothing catches. It makes a whirring noise but the engine doesn't start trying to catch really. I tried jumping my car but no luck. This problem occured before when it was cold but it would catch after 2 or 3 times. I also had a whole tune up 2 weeks ago. New plugs and all sorts of stuff. A trip to the mechanic is probably inevitable, but maybe I can atleast figuere out what is wrong. Any ideas?
Old Apr 24, 2003 | 01:23 PM
irocz8957's Avatar
sounds like a bad starter!
OsirisMajor's Avatar
I'm no wiz at remote starts but i would say always check the battery cables. Maybe they're a little loose. If they have crud and white deposits around 'em pour some cola on em and it'll clean them off.
Old Apr 24, 2003 | 01:25 PM
irocz8957's Avatar
oh yeah to amke sure its the starter get under your car and locate the starter and there should be a things that spins on the starter if that doesnt spin it means you starter is bad hit with a wrench and try to break it lose when it happens!
Old Apr 24, 2003 | 02:02 PM
I disconnected the keyless entry and remote starter unit and teh car still doesn't start. I think it could be the starter then. I find it wierd that it just broke over night and was fine before (except when it is cold). Its been working great for a while. Where are the starters on the firebird? I don't really know what to look for and my brother is at work so he can't help me yet.
Old Apr 24, 2003 | 02:48 PM
Black6SpdTA's Avatar
wheres the "whirring" noise coming from? did you check the battery? does everything inside the car work (lights, radio, etc)?
Old Apr 24, 2003 | 02:49 PM
I am starting to worry that it may be something serious. It just broke overnight (or maybe becuase of that damn remote starter kit, but I can't imagine why). So where can I get the cheapest starter? This sucks I can't even get my car to the shop without it being towed.
Old Apr 24, 2003 | 02:52 PM
Everything works like it should and the keyless entry is working. The whirring noise is the fuel pump I was told. My battery is above 12 volts and we tried jumping my car to make sure. All I did was try to start the car twice with the keyless entry, I realized it wasn't working so I was going to take my car around the block and it wouldn't start. Could I have fried something? The unit is wired in correctly and I have pressed teh button in the past and it didn't cause any problems.
Old Apr 24, 2003 | 04:17 PM
LandryP's Avatar
My Camaro does the same thing. The starter spins but the gear won't engage the flywheel (whiring noise) I replaced the starter with a used one from an my old 86 and it worked fine for couple weeks now its doing it again so either i got two broken starters poorly shimed starter or im missing some teeth of the flywheel, you probably have one of these also.
Old Apr 24, 2003 | 04:23 PM
LandryP's Avatar
By the way a remanufactured starter with a lifetime warenty from autozone is something like $20 and easy to replace with a 15 mm deep socket and an 8 mm socket if I remember corectly
Old Apr 24, 2003 | 05:03 PM
Thanks so much Landry. How much will a flywheel run me? I just got the repair guide from the library that covers EVERYTHING. Also, I went to AAP and they said $45 for a starter.
Old Apr 25, 2003 | 12:22 PM
It was the starter. Works great now, thanks guys.
Britbilly
Jan 7, 2015 08:49 PM
Dec 4, 2014 11:56 AM
Dyoung_Z28
Nov 25, 2014 05:26 PM
USAirman93
Nov 24, 2014 03:37 PM
lbrowne
Nov 13, 2011 04:25 PM
