My 383 stealth ram build
Old Jun 12, 2008 | 08:51 PM
  #31
rik89gta's Avatar
Hellzzz Yeah! Can't wait to hear that motor run!
Old Jun 15, 2008 | 12:20 AM
  #32
Orr89rocz's Avatar
basically looks the same as last years HSR L98 its the insides that count
Old Jun 15, 2008 | 08:31 PM
  #33
Orr89rocz's Avatar
THE BEAST LIVES FOR NOW
First start up as expected this weekend. actually today Car has oil leak so i have to redo gaskets but for now its awesome
Rough base tune, high idle... erratic bouncing 950-1100 rpms or so. Vid does not do justice..its louder and more deep sounding than what the cam pics up. Oh well, once its smooth and tuned, i'll get more for sure!!!
http://media.putfile.com/383-Stealth-Ram-Startup
Old Jun 16, 2008 | 11:44 AM
  #34
MaxxMitchell's Avatar
Awesome news man.
Old Jul 12, 2008 | 08:35 PM
  #35
Orr89rocz's Avatar
New updates. wow alot went on pulled manifold to replace gasket/seal beads on the walls and i found that the rear oil galley plug was just loose so i was upset i had to pull all that stuff but oh well
finished the exhaust...went with a new muffler, dynomax ultraflo round 6" case 4inch inlet/outlet. Much quieter but still very loud if that makes sense i like it tho. Added dual 3inch tail pipe exits and 3.5 inch tips like i had last year. So the exhaust basically mimics my old setup
had to pull the y pipe to fix a o2 bung location and some mild leaks in the welds. I suck at welding but i patched everything up i think
Added LC-1 Wideband and G3 gauge kit and started tuning. Car idles decent in park/neutral but wants to surge/stumble in drive. I'll fix that soon tho. WOT tune is based right now, i have it safe 12 to 1 for the most part til i get to the dyno later these upcoming weeks
cant wait to see the results but i can tell you the car doesnt quite feel as 'fast' as i thought it would. But i only took it over 6000 rpms once today and it felt better than the 5000-5500 rpm pulls. So thats good but still doesnt 'scare' me like i thought i was gonna be. kinda doesnt feel that much faster than my old L98 in the mid range which is weird but oh well, we'll see once its tuned up
Old Jul 13, 2008 | 01:49 AM
  #36
AutoRoc's Avatar
Nice to hear! I bet it's light years faster, it just doesn't have that crazy torque spike down low FOLLOWED by a very fast HP drop off... My 14.40 TPI IROC put you in the seat like an 11 second car but it only did it for about 2 seconds.
Old Jul 13, 2008 | 10:52 AM
  #37
Orr89rocz's Avatar
it feels quick but then again i have no idea what a quick car feels like. My 12.90 Irocz was as fast as i have ever been. This car feels faster than that but i wouldnt say super fast. But i havent been over 5500 rpms much with it yet
Old Jul 16, 2008 | 09:50 PM
  #38
Orr89rocz's Avatar
First drag results in tonight! vid coming soon
rough street tune with 38-39 degrees timing (abit high) and roughly 12.5 ish to 1 air fuel ratio
Softer launch but still quite stout at
1.59 60 foot
7.429 at 92 1/8 mile
11.67 at 116.3 mph 1/4 mile
that was best pass of night. Having abit of a miss or something up top, i think its a bad plug wire it got burnt and was laying on the header the last run so i'm gonna get some better wires here soon
i was expecting mid 12's. This car really doesnt feel as fast as it is and that kinda sucks
heres vid link..... just uploaded now so it may take a min or two to fully load. vid quality may not be the best but you get the idea
http://media.putfile.com/383-HSR-first-14-mile-passes
also, yes i did peel the hood louver off the hood on first pass. you can see it near 1000 foot mark in vid first pass
Old Jul 17, 2008 | 07:36 AM
  #39
The car seems to leave pretty well, with more left in it there! I was shocked the same way as you, when your car feels like a 12sec car, and you go and run 11's with it, makes it feel easy lol. Then if your like me, you have friends with mid 10sec street cars that are tame compared to mine, and after a few passes in those, its like, MAN, now I gota go for 9's to feel fast again
I would say you still have some power locked up in there. What does your car weight? I’ve seen identical times ran by another friend of mine's car that weighted ~3700 and made ~370rwhp (auto).
Old Jul 17, 2008 | 12:24 PM
  #40
onefastgta's Avatar
Car runs good! Way quicker than mine.
Old Jul 17, 2008 | 04:16 PM
  #41
Orr89rocz's Avatar
well last year the car weighed about 3460 with me in it. with aluminum heads/waterpump/ministarter i think i would be near 3400 ish with me in it
so with more power from better tune i expect this car to go alot quicker than it has...especially since it was sooo hot
Old Jul 17, 2008 | 05:43 PM
  #42
rik89gta's Avatar
Man! That car leaves the line pretty hard! You still running the 4th gen 10 bolt with the 3.42's? What kinda tires are You using?
Old Jul 17, 2008 | 06:33 PM
  #43
Orr89rocz's Avatar
haha yes, and i'm nervous it wont last! it left the line pretty hard but like i've mentioned, there is alot of room to improve. I spun 1 run and the other run felt like it chirped abit. I only gave it about 75-80% i'd say. i think it has high 1.4's in it once i get good gears for the car and give it hell!!
running 26x10.50 ET streets. I never had another tire they hook great and are streetable too
Old Aug 2, 2008 | 06:06 PM
  #44
Orr89rocz's Avatar
Dyno'd it... alittle off what i was expecting but shows the car is doign good in the 1/4 for the power thats for sure
http://media.putfile.com/383-Stealth-Ram-dyno-run
Old Aug 3, 2008 | 01:12 AM
  #45
AutoRoc's Avatar
[QUOTE=AutoRoc;5291644]That's a 10 second combo all day when you get it tuned, hooking, and in a 3200-3300lb car.
QUOTE]
I'll quote myself... Converter sounds great also! New tune, correct timing, cold air, maybe shed a few more pounds out of it...This thing will FLY. When's the 100 shot get plumbed!?!
