Muffler advice needed
Old Aug 9, 2005 | 03:27 PM
91-Z28-L98's Avatar
I'm planning on getting a dual 2 1/2" exhaust setup exiting before the rear axle and I would like a muffler pair that sounds somewhat more aggressive than stock but not obnoxiously loud (so no bullet mufflers). More importantly, I want to minimize ground clearance issues so it needs to be as thin as possible. Of course I also want as much flow as I can get while still adhering to the above constraints. Anyone have an idea of some mufflers that can meet my criteria?
Old Aug 9, 2005 | 04:06 PM
RedThunder1994's Avatar
Re: Muffler advice needed
a nice pair of muffler bearings increase performance and sound
Old Aug 9, 2005 | 05:24 PM
RedIrocZ-28's Avatar
If you want the best sounding mufflers but still be quiet, a bit of advice. The muffler has to have a "straight through" design and have a large inside volume. The large volume is what helps to absorb heat and vibration, which in a smaller muffler translate into more sound. So, look for as large of a muffler as you can fit under the car without sacrificing for your above criteria. I got a Single in Dual Out Dynomax setup with a 24" wide muffler! Its relatively quiet at idle, and only gets really loud when you mash the loud pedal.
Good luck.
Old Aug 9, 2005 | 05:58 PM
91-Z28-L98's Avatar
Looking on Summit Racing, I saw a bunch of 4" thick mufflers that would probably work, but I also saw a 3" think flowmaster 50 series. How well does this muffler flow? I hear its pretty loud, but I would like to hear from someone who has it or knows someone who does. I don't think its a straight through design either.
Old Aug 9, 2005 | 06:23 PM
doug791's Avatar
i have a dynamax 3"single in 3" single out and it sounds badass on my y-pipe
Old Aug 9, 2005 | 07:02 PM
91-Z28-L98's Avatar
http://store.summitracing.com/defaul...1&autoview=sku
Would this muffler be a good combination? It will probably be thin enough at 4.5" but I'm just worried it will be too loud.
Old Aug 9, 2005 | 11:52 PM
klumb15's Avatar
i have 4" spintechs...too thick if you ask me...i'm lowered 2 inches too, and i scrape once in a while...
Parts Wanted
Mar 17, 2015 11:24 PM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
1775.Z28
Jan 11, 2015 10:51 AM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
