Map sensor vac port
Old May 28, 2005 | 08:46 PM
Dark Angel's Avatar
Map sensor vac port
My neighbour has an '87 Firebird. It's 305/350 (not sure) with a quadrajet. I was looking at it today and noticed that the MAP sensor on the left side of the firewall has no vac line running to it. Where should this be hooked up to? There are no spare ports, but the lines have been messed with anyway, so if there was a t adapter, it's long gone..
Also, There is an EFE that runs off a vac line. This is some type of valve on the passenger exhaust downpipe. This I see hookes to a T with the PCV line. The T is missing and this isn't hooked up. What does it do and will it hurt not being connected.
Thanks.
Old May 29, 2005 | 05:51 PM
Kevin91Z's Avatar
3rd Gen Tech Moderator
Re: Map sensor vac port
I can provide some info, but I'm not a carb expect. Hopefully someone who is will post here.
If the engine is stock, its a 305 called the LG4. The MAP sensor should be hooked up to a vacuum source from under the throttle blades. I dont think it matters much which one. The EFE valve is for cold starts. It closes when the engine is cold and that sends the exhaust back thru the intake manifold to heat it up faster and provide better fuel/air atomization. After the engine warms up, the valve opens and the exhaust travels normally thru both exhaust manifolds.
Old May 29, 2005 | 08:37 PM
Ben91RS's Avatar
This might help: http://www.autozone.com/images/cds/g...3d80163819.gif
HectorM52
Jul 30, 2017 11:46 AM
mightymouse383
Jul 20, 2016 07:34 AM
oldschool
Feb 9, 2016 09:21 PM
99TransAmWS6
Mar 22, 2015 11:00 PM
Fatdog2
Feb 13, 2015 08:19 PM
