lt1 manifold vrs l98
Old Mar 31, 2007 | 09:06 AM
deathlessone's Avatar
which manifold is better? my brother had a 96 z and put headers on it and i was wondering if they would have better flow then the l98's?whats your opinion?
Old Mar 31, 2007 | 09:13 AM
Marc 85Z28's Avatar
The LT1 intake manifold is far superior to the L98s TPI. The only problem is that its not a direct bolton - it requires quite a bit of modification to fit. See www.LT1intake.com for more info.
If you're talking about the exhaust manifolds, forget about it. As is the case with all cars, exhaust is chassis specific. The manifolds will bolt up to the heads, but you'll never be able to fabricate a y-pipe to make them work due to the different routing of the exhaust between the 2 cars.
Old Mar 31, 2007 | 07:55 PM
LesPaulGoth's Avatar
LT1 = more hp and higher range
L98 = more initial tq, but very short rpm range, restricted power up top.
Old Mar 31, 2007 | 08:25 PM
DarthIROC's Avatar
From: Teeter-tottering between Brilliance and Insanity
Exactly, but the LT1 in initself makes alot of toruqe in the low range. I guess that just goes to show how weak the TPI is uptop. In reality the TPI is probbaly the best intake ever designed...... for a 4x4
Old Mar 31, 2007 | 08:57 PM
1LESSZ28's Avatar
Of you like torque go with tpi. more rpm range and power up top go with the lt1.
I wouldn't go with either one personally. They both are at complete opposite ends of the spectrum. one has long runners for good torque production but a small plenum and restrictive base and the other has more plenum but 3" runners not ideal for torque. The best in between in the super ram. The best highend for the l98 is the stealth ram. In an article I read the mini ram (with is better than an lt1) made the same power up top as a stealth ram but the stealth ram had a much fatter torque curve and made a lot more power due to more plenum room and longer runners. Porting a stealth ram wouth produce even bigger gains and porting a stealth ram is arguable easier than an lt1 manifold.
Old Mar 31, 2007 | 09:47 PM
DarthIROC's Avatar
Yeah i agree the holley stealth ram is the best option if your an L98 looking for improvement.
DirtyDaveW
Dec 1, 2016 05:37 PM
Noer
Feb 28, 2015 11:29 AM
Jul 4, 2005 05:00 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
Chris Ja
Aug 1, 2002 07:30 PM
