ls1 one in a 3rdgen
Old May 12, 2003 | 11:00 PM
crazyk1le's Avatar
Unhappy ls1 one in a 3rdgen
now i've got to make a dis. and i need real info and you guys have been great, so here goes i'm thinking of putting an ls1 in my car and i have a few questions first is it worth it $ wise i mean compared to if i built a convential 350
2. are there headers for the ls1 that will fit our cars part two of this ques. with the way our exhaust runs will it flow enough for the ls1
Old May 13, 2003 | 02:59 AM
Zepher's Avatar
Cost effective? Nope.
But it is a very eye catching swap.
As far as I know, there aren't any LS1 headers that will work with our cars.
The manifolds are enough to get the car to run mid 11's.
Go to www.speartech.com and check out thier LS1 powered Camaro.
Old May 13, 2003 | 08:30 AM
fb305svs's Avatar
yeah you have to use either custom headers or the stock manifolds
Old May 13, 2003 | 09:08 PM
crazyk1le's Avatar
Talking reply
thanx guys for the info my problem is i took my tpi apart and one it's very complex to put back together, not only that what i mean is i'm putting together a really nasty car and i love after market parts also i love seeing a car with the best of everything and i can't see putting the $ into the tpi unit it's so expensive for what i gues is marg. gains at best, tell me what you think, i'm not an expense freak either i love the idea of using all gm parts motor wise like fastburn heads scroggin dickey base etc. so it doesn't have to be a million dollars for me to like it
Old May 15, 2003 | 09:57 AM
user 647483's Avatar
Actually, I was reading an article on that the other day.
There was one maufacturer's headers which does clear the
3rd gen's frame. I'll see if I can find it.
Old May 15, 2003 | 11:43 AM
jayman350's Avatar
if you've got all the wiring and stuff for the tpi setup still then you might think about doing an lt-1 intake swap. Check out http://www.lt1intake.com/ this tells you pretty much everything that it entails.
It will be way way cheaper than putting an ls1 in, and thenyou can use the leftover money for more mods
Just an idea, that and you mentioned sticking w/ all gm parts
13qtr
Oct 28, 2016 08:11 PM
Ericksd
Jan 20, 2016 06:07 PM
Hal Fisher
Sep 30, 2015 09:03 PM
Z Power
Sep 19, 2015 11:19 PM
1slow93z28
Sep 1, 2015 06:22 PM
