Loose door handles
Old Jul 29, 2003 | 10:51 PM
  #16
Pro
Guest
Posts: n/a
Hey, I tried to get a pic of the upper part of the door. Do these bolts look right?
ftp://68.1.231.79/camaro/door.jpg
I thought they were kind of small for what they should be, but they came off pretty easy.
BTW I took the handle off, and moved it down a little bit into the grooves, and it tightened the rod up a little. Now there is just a little play between the base and the actual moving handle.
Old Jul 30, 2003 | 12:03 AM
  #17
DanTheIROCMan's Avatar
Yep, those are the stock nuts. Just tighten them up real good with a pair of long needle nose. They should fit in there real nice. Also, as mentioned in my earlier post, if I recall correctly, even though you tighten them up, they will still appear to be a little wobbly because the handle itself doesn't not seem to fit real tight on the base.
2QUIK6
Sep 17, 2016 02:31 PM
Henson071
Sep 18, 2015 04:01 PM
cohopefull
Sep 8, 2015 03:22 PM
cmsmith
Aug 9, 2015 07:30 PM
CARiD
Jul 7, 2015 08:19 AM
