Looking for L98 Replacement
Old May 27, 2008 | 10:16 PM
JohnW42598@aol.com's Avatar
My '92 L98 is getting tired with 170K. I'm interested if anyone can recommend a reliable reasonably priced crate replacement with 300-325 hp that will work with the stock TPI and engine computer. Next question - any suggestions on what needs done for the tranny not to grenade? Thanks.
Old May 28, 2008 | 10:03 AM
Rice Killer87's Avatar
This doesnt have prices,but will give you an idea of whats out there.
http://www.gmperformanceparts.com/Pa...l.jsp?engine=0
I like the 350 HO with the 330HP 380LB/FT of torque....the only problem is that its running Vortec style heads and you'll need an aftermarket base plenum because the bolt locations are different and they only have 8 instead of 10.
As far as the transmission goes,a good rebuild with a decent shift kit and external trans cooler and you'll be fine.
Old May 29, 2008 | 05:31 AM
ws6transam's Avatar
Scoggin Dickey has a TPI base to fit Vortech heads. It would probably make a fine package. You might need to learn how to reprogram the ECM though. It's not that hard anymore, especially with the stuff out there for TPI by Craig Moates.
Old May 30, 2008 | 07:54 AM
1987IROC350's Avatar
I bought the Scoggin Dickey crate Vortec TPI engine. It's rated at 360hp and 412lb ft. http://www.sdparts.com/product/SD360...ripEngine.aspx
But if I had to do it all over I'd get, for a really easy install, the ZZ4 with a hot cam http://www.sdparts.com/catalog/crate...ZZ4Engine.aspx
Or the 350HO http://www.sdparts.com/product/12486...ateEngine.aspx
Old May 30, 2008 | 11:52 PM
Kevin91Z's Avatar
3rd Gen Tech Moderator
The HOT cam will require a custom computer chip. The ZZ4 cam will not. However the ZZ4 heads are the same as the L98 Corvette heads and have their own problems.
Old Jun 4, 2008 | 03:08 PM
detltu's Avatar
What kind of problems do you mean. I am thinking about the ZZ4 for my 91 eventually and probably won't go with the Fast burn because they are vortech. What is the problem with the L98 heads?
Old Jun 8, 2008 | 02:24 PM
Kevin91Z's Avatar
The L98 heads have no exhaust crossover, so you'll need to hook up an external EGR like the Corvettes do, and use an aftermarket TPI intake. They are also missing a bolt hole so you'll need to drill and tap one for the serpentine belt accessories. Lastly, they have the old style intake bolt angle like on the '86 and earlier perimeter bolt heads, but if you're using an aftermarket TPI intake for the EGR, you'll be fine.
One final thought, if you're expecting to make a lot of power with the L98 heads, forget it. You'll be a lot further ahead with Trick Flow or AFR heads. The L98 heads are great for a stocker or daily driver. They dont flow enough for a street/strip car, unless you're happy with mid-13's.
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
ANDYZ28
Dec 29, 2014 09:13 PM
Hurin
Dec 13, 2014 07:38 PM
kandied91z
Sep 14, 2002 08:37 PM
Chris Ja
Aug 1, 2002 07:30 PM
