Looking at an '86. Few ?'s...
Old Apr 10, 2003 | 02:42 PM
JAMIROBri's Avatar
Question Looking at an '86. Few ?'s...
It's an '86 Camaro with 305 (carb), T-tops , auto. and 37k miles. What should I look for problem-wise? What kind of gas milage can I expect? I'm looking at using this car as my daily driver. Thanks!
Brian
Old Apr 10, 2003 | 09:07 PM
DarthIROC's Avatar
From: Teeter-tottering between Brilliance and Insanity
well first off. The 3rd gen odometer only goes to 99,000 I think so I would be weary of the car actually having 137,000 miles on it. And is it a stock like H.O. set-up with a carb on it or is it an aftermarket carb set up?
Old Apr 10, 2003 | 09:49 PM
JAMIROBri's Avatar
Thumbs up
It's completely stock and I believe them when they say it's 37k. They're the original owners on it and the car is in pristine condition. Thanks for the response so far!
Brian
Old Apr 10, 2003 | 10:17 PM
colin911's Avatar
my odometer goes up to 999,999
My odometer
Old Apr 10, 2003 | 11:05 PM
DarthIROC's Avatar
My odometer
I think most just have the 85 mph speedo like mine though that only goes to 99,000.
Old Apr 11, 2003 | 09:00 AM
Jim85IROC's Avatar
My odometer
That's not the stock gauge. The ONLY speedo available in 85 was the 85mph speedo. The stock 140mph speedos from later years had numbers in 10mph increments and lines in 5mph increments. I've only seen one like yours a couple times, and I believe it's an aftermarket unit that was available in the early 80s.
Old Apr 11, 2003 | 11:57 AM
greg97's Avatar
Mileage:
I used to get around 15-18 mpg with the quadrajet.
Areas to check:
Bushings, Belts, and stop bumpers (in other words, all rubber that can rot simply with age.) Condition of the rear end (pull off cover and look at metal shavings on magnet)
Good Luck
edit: Check your vac lines too.
Old Apr 11, 2003 | 03:09 PM
colin911's Avatar
It is stock my friend! thats 140 KMH not MPH remember, the kmh is in white, mph in blue
Old Apr 11, 2003 | 09:07 PM
TheGreatJ's Avatar
Gotta love them metric Canadians, eh?
Old Apr 11, 2003 | 09:53 PM
colin911's Avatar
metric Canadians? try metric EVERYONE except the States
Old Apr 12, 2003 | 01:06 AM
aziroc's Avatar
i have an 86, it has the *stock* (im 2nd owner.. 1st owner was soem old dude ) 145 speedo and only goes to 99,999.
gas milage.. i know my 305 tpi was crap. and IMHO.. get a 87-90 camaro.. as much as i LOVE my 86 iroc.. this thing had SO many problems.. and every 86 owner i talk to as had the same things go wrong.. but the 86-90 guys dont ahve nearly as many issues as i do.
Old Apr 12, 2003 | 09:25 PM
Sitting Bull's Avatar
Re: Looking at an '86. Few ?'s...
Brian
That car should run like a charm if it only has 37000 miles
My 86 Sport Coupe got about 17 to 18 mpg around town when it was stock. Now that I've hopped it up like crazy it STILL gets 16 mpg but has TWICE the hp
There aren't really any problem areas that set the 86 Camaro apart from other years. They made a change in the 700r4 tranny in 87 that eliminated a small clunk sound when you put it in gear but that's about it. Since it is carbed, it is about as simple as an engine gets from that era.
Nayr
Mar 3, 2023 08:34 PM
willie-d-nice
Feb 13, 2015 06:40 AM
Punisha69
Aug 24, 2003 12:29 AM
streetracer9698
Aug 17, 2003 07:47 PM
iroczinoz
Aug 12, 2003 08:42 AM
