learned something about cam timing
Old Dec 2, 2003 | 10:24 PM
mrr23's Avatar
was looking at the cam i'm going to use. well they have it listed for the LT1 and for the earlier engines. same specs. or so i thought. both are
220/230 @ .050
.510/.510 lift
but i looked closer at the actual cam cards for these 2 ALMOST identical cams. the point at which the valves open and close are different. so, i plugged them into DD2000 and got this difference.
hp compare
http://www.stealthram.com/images/l98lt1hpcompare.gif
tq compare
http://www.stealthram.com/images/l98lt1tqcompare.gif
here are the open and close points for each cam. this is in crank degrees. the L98 style has more below 4500. the LT1 has more above 4500.
07-305-8 L98 cam profile
IO 28 IC 68
EO 83 EC 27
08-305-8 LT1 cam profile
IO 0 IC 40
EO 53 EC -3
rideordie
Nov 5, 2019 04:52 PM
HectorM52
Jul 30, 2017 11:46 AM
Queens94z28
Dec 20, 2014 09:11 PM
Noenav
Dec 6, 2014 07:35 PM
