L98 Heads
Old Mar 28, 2006 | 04:56 PM
89_Irocz's Avatar
L98 Heads
Does anyone what the specs are for the stock 89 L98 heads? And whats the most HP you can get and still use the stock heads?
Old Mar 28, 2006 | 10:29 PM
LesPaulGoth's Avatar
Re: L98 Heads
Valves:
1.94 intake
1.5 exhaust
Combustion Chamber:
58cc (Aluminum Vette Heads)
64cc (Iron Camaro, 'Bird, TA heads)
Flow #'s (int/exhaust) - These are the 58cc Vette Numbers, they should be very close in the ballpark, if not the exact same.
0.1" lift 55/52
0.2" lift 120/104
0.3" lift 160/133
0.4" lift 186/151
0.5" lift 196/170
Not sure on the runner volumes, but its probably not that impressive.
Trickflow had a match against Vette L98 heads and flowed 40hp better. At the time, the L98 was making 420hp. So I guess you could get that high, but it would be tough, and you'd have alot of porting to do. Honestly, I would just get new heads. Trickflow's 23 degree aluminum heads are $1145.95, which is a pretty good deal.
Old Mar 29, 2006 | 12:30 AM
91Z-28's Avatar
Re: L98 Heads
163cc intake runner.
Old Mar 29, 2006 | 12:32 AM
91Z-28's Avatar
Re: L98 Heads
http://purplesagetradingpost.com/sum...fo/heads1.html
http://chevyhiperformance.com/techarticles/41598/
Victor Lamb
Aug 26, 2017 02:52 PM
Roadie
Feb 16, 2015 10:34 AM
NewsBot
Jan 29, 2015 07:10 PM
NewsBot
Dec 28, 2014 06:20 PM
