L03, LB9, L98 intake questions
Old Dec 29, 2003 | 10:27 PM
BigCasino87GTA's Avatar
From: Chillin' with Frank, Dino, Sammy and Pete at the Sands!
hey guys 2 quick questions...will the TBI intake from an L03 bolt on to a 350 L98 block?
second question, what's the difference between an L03 and an LB9?
trying to help a friend out here, any help would be appreciated
Old Dec 29, 2003 | 10:31 PM
chevyman502bb's Avatar
why would you want to put LO3 tbi intake on an L98? thats whats called automotive suicide.....powerwise......LB9 is TPI305 and LO3 is TBI 305
L98 = TPI 350
LB9 = TPI 305
LO3 = TBI 305
Old Dec 29, 2003 | 10:32 PM
haha, not me pal, a friend wants to do some intake mixing and matching, my TPI is staying put
EDIT: forgot to say thnx !
Old Dec 29, 2003 | 10:35 PM
ahhhhhhh lol
well sinse the LB9 and L98 r basicly the same besides bore, and ive seen LB9 intakes go onto LO3's......i guesse it should work, tho i think its a waste of time......sinse ur friends has an L98 block try to convinse him to use the tpi or mini ram or somn.....save him some time, money and give him alot more power
Old Jan 7, 2004 | 09:57 PM
MY91Y84's Avatar
The difference between the LO3 and LB9 was basically a cam head swap....the LO3 was 170HP and 275Lb feet, the Auto LB9 was 195-205HP and 285-295lb ft,...while the hottest LB9 was 230HP and 300Lb feet
Old Jan 7, 2004 | 10:50 PM
94LT1Maro's Avatar
What did the hottest LB9 have on it to get 230 horses. Because if I can do that to my L03 and save me the pain of an Engine Swap i'm gonna do it lol.
Old Jan 8, 2004 | 08:50 AM
Do a search on the G92 ( or 42? not sure which ) optioned LB9. I think a board member here has one as well.
Old Jan 8, 2004 | 01:55 PM
cronsformula350's Avatar
With stock heads, the motor would probably be ok, but I would still probably port match and extrude hone port the intake, to make it flow more on the 350. Tbi's are still pretty good although there on the lower line of vehicles. You may lose a little power, but it will work.
Old Jan 8, 2004 | 02:24 PM
aklim's Avatar
Get a better intake system. LB9 and L98 both suck.
Old Jan 8, 2004 | 02:52 PM
MY91Y84's Avatar
well i am a board member that has one...you are right its G92
it was a package called R6P for 90+ firebirds (mines a GTA)....it had 4 wheel discs, oil cooler, dual exhaust, 3.42 gears (LB9), aluminum drivshaft, aluminum spare....the RPO G92 was included in R6P...when i first got the car i didnt know that....i knew it had 3.42's instead of the 3.08's that came standard with the 5 speed cars, but i didnt think it was a G92 car...there were only 164 GTA's made in 91 with G92 and LB9...it's a t-top car so it isnt that "rare" but i figure after 13 years there arent to many like it on the road still...
basically its was a 5 speed LB9 with the L98 cam and 3.42 gears...
with basic mods (K&N, flowmaster and the EGR walls ground down, the best my Lb9 ran was 14.1@almost 97....but i also tried everything i could to break it....
to bad i didnt take the pics of my 2nd and 3rd gear clutching teeth when i rebuilt it
94LT1Maro...your in luck bud....i have my complete LB9 for sale...
youd have to change the cam and heads, and put on the TPI intake....the only thing that would be different would be the exhaust...The manifolds and the N10 setup...i have 1 manifold but the other and the N10 was unusuable so i canned them...
PM me if your intrested
Old Jan 8, 2004 | 07:47 PM
94LT1Maro's Avatar
Thanks for the offer lol but I don't see a total engine swap in my future right now. I just can't afford it lol I see just doing the TPI Swap, L98 Cam, and whatever else was done to the 305 to punch 230hp from the factory as enough for now. Just doing that will save me a crap load of money as far as i'm concerned and give me the power I want. Thanks again though and if you can give a link to a website that would have some information about that particular engine package i'd sure appreciate it b/c this is a more sensible route than doing a complete motor swap..............well at least for now b/c I know my 305 won't last forever
Old Jan 11, 2004 | 12:20 PM
MY91Y84's Avatar
have a pm
Old Jan 11, 2004 | 02:25 PM
Kevin91Z's Avatar
3rd Gen Tech Moderator
A better cam, and a better exhaust system.
oldschool
Feb 9, 2016 09:21 PM
mikey4play
Mar 15, 2015 11:45 AM
djangoroar
Parts Wanted
Feb 21, 2015 11:47 PM
LT14LIFE
Feb 9, 2015 09:35 PM
89 iroc zl1
Jan 14, 2015 02:18 AM
