knocking when turning?
Old Jun 6, 2008 | 12:31 PM
00ls100's Avatar
hey I have a 92 RS and when I make turns, like turning into a parking spot and I have to turn the wheel a lot something makes a bump bump noise? does anyone know what it is? I want to replace it so it doesn't sound so aweful lol thanks in advance
Old Jun 7, 2008 | 08:25 AM
ws6transam's Avatar
It's hard to say what the noise could be: Have you removed the wheels and looked around yet? It could be a bad rotor. It could be worn-out lower ball joints, too. Is it a big, loud popping noise that happens just once? If so, it could be the spring moving around on the spring perch. Mine does that, too. It started when I cut my springs and I dont worry about it much. If the popping is consistent with a rotating tire, check your inner fenderwell and see if it is interfering with the tire. Mine does that too, especially with 17 x 9.5 inch wheels out front!
Old Jun 7, 2008 | 09:22 AM
lordmetalz28's Avatar
miine kinda squeals???? any info on that
Old Jun 7, 2008 | 10:41 PM
briggsbuilder's Avatar
maybe the shock/strut mount support??? thats wat happened on my brothers older camaro
Old Jun 9, 2008 | 10:09 AM
00ls100's Avatar
would it be the ball joint if i'm turning the wheel to the max and it makes like a ... BUNK noise? it's hard to explain lol. thanks for the replies
Old Jun 9, 2008 | 01:15 PM
redneckgames's Avatar
I have the same problem, when I turn the wheel to full lock, something pops. I was told it is the upper strut mount. Im not sure, but I do have new ball joints so that shouldnt be my problem anyways.
Old Oct 25, 2008 | 07:03 AM
99Blackt/a's Avatar
Just an idea, but check your tie rod ends
Old Nov 20, 2008 | 01:57 PM
Castro's Avatar
Check your ball joints and get them fixed. This is actually an easy repair and they lend you the tools at auto zone. Sounds to me likes its the ball joints.
Old Apr 3, 2009 | 12:05 AM
camaro91boy's Avatar
dose the sound come from the rear? mine did it in my 91 z-28 expecially after numerous burnouts. try with the car in park pushing it back and forth in the rear fender if you hear the clunking noise it is your shims worn down in the axle. i bet if you try burn outs you get alot of one wheel peels and then sometimes it will lock both. i did it to mine and fixed it.
Old May 8, 2009 | 11:08 PM
sbarnes's Avatar
bumping noise
I have a 1989 IROC and had the same problem. mine turned out to be the trans. mount. the drive shaft was hitting when I was in a sharp turn.
Old May 9, 2009 | 12:24 AM
chevyz4life's Avatar
knock
maybe wheel bearings
Old May 9, 2009 | 05:02 PM
camaronutt's Avatar
check the steering box for tightness and all the other components. Get someone to turn the wheel while you listen.
HectorM52
Jul 30, 2017 11:46 AM
BigWil
Mar 29, 2015 12:24 PM
HectorM52
Mar 15, 2015 10:45 PM
formula79
26
Aug 5, 2002 12:21 PM
