jack up the back
Old Sep 12, 2003 | 06:13 PM
CamaroZ28Coupe's Avatar
jack up the back
where are the best places to jack up and support the rear of an 83 z28. im painting the rear end of my car with por-15 and i need some room to work.
Old Sep 12, 2003 | 06:36 PM
mechanicZ's Avatar
you can always do it on the rear axle. just do not jack it up on the side there the body meets the frame, it is weak and folds.
Old Sep 12, 2003 | 07:13 PM
so can i put the jack right on the differential where should i put the jack stands
Old Sep 12, 2003 | 09:02 PM
mechanicZ's Avatar
just keep them on the axle, i've not even look at my rear end in awhile, but i''ll look under her 2morrow and give u exact places to lift. pretty much thought if it looks stong it can go, but just ease the jack down if u want 2 try it urself.
Old Sep 12, 2003 | 09:45 PM
Black6SpdTA's Avatar
I put the jack directly under the pumpkin (differential) then the jack stands on the axles.
-Rippin
Old Sep 12, 2003 | 10:41 PM
aklim's Avatar
Either the pumpkin or you can get the jack under the LCA where it mounts to the chasis. Don't forget the back is up and now you have nothing to stop the car going forward. E brakes work on the back wheels. Be smart and use wheel chocks for both in front and behind both tires.
Jan 23, 2015 01:13 PM
ModdedNerd
Jan 1, 2015 10:56 AM
squarehead
Nov 21, 2014 08:02 PM
firebirdude
Aug 7, 2002 07:31 AM
