IrocZ Gears
Old Dec 10, 2003 | 09:51 PM
CRZYPWR's Avatar
IrocZ Gears
Hey guys. I was just wondering if Gears from 2000 Camaro will fit 87 Iroc Z. I dont know whats the rear end in Iroc thats why I am asking. Thanks a lot !
Old Dec 10, 2003 | 11:23 PM
90rocz's Avatar
Yes it's a 7.625" or 7 5/8", but is still sometimes refered to as a 7 1/2" rear...I have a Zexel Torsion Posi same as a late model Z.
Have you checked the ratios to see what you already have, see the numbers stamped on the ring gear as 42:13, divide the two and you get 3.23's...
Old Dec 10, 2003 | 11:53 PM
Kevin91Z's Avatar
3rd Gen Tech Moderator
No, it depends. The 87 IROC can have a 9-bolt rear end, or a 10-bolt rear end like the 2000 Camaro. What engine is in the IROC? That will help. If its a 350 engine, then you definitely have the 9-bolt rear end.
Old Dec 10, 2003 | 11:56 PM
Zepher's Avatar
It will also depend on what series carrier you have and what the 00 Camaro has.
3.08 and numerically lower gears are 2 series carriers and 3.23 and numerically higher are 3 series.
CRZYPWR's Avatar
The gear from the 00` Camaro is 3.23 ratio. The engine in Iroc is a 350.
Old Dec 11, 2003 | 01:13 AM
90rocz's Avatar
The then the IROC gears will need to be 3.23 or higher number as said, or you'll need a ring gear spacer. And yeah, I was assuming you meant they were both 10 bolts', ID'ed by the number of bolts in the rear cover. I'd find some 3.73 GM's out of an S10....
Old Dec 11, 2003 | 02:48 PM
lordmetalz28's Avatar
does anybody know about a ford 9 bolt made for our cars id like to buy one either that or rebuild my rear bullet proof i have a 10 bolt 7.5 they only one which came in the 305tpi
CARiD
Apr 8, 2015 08:08 AM
STR FTR 1
Feb 10, 2015 10:36 PM
hotrod 5210
Dec 22, 2014 07:28 AM
ReznorZ28
Aug 27, 2002 03:53 PM
