iroc-z28 question
Old Apr 20, 2003 | 06:26 PM
doug791's Avatar
iroc-z28 question
for the 85-87 camaros they made 2 different models the iroc and the z28 what is the difference between the two?
Old Apr 20, 2003 | 06:55 PM
MasterEvilAce's Avatar
this might help some?
http://www.camaro3rdgen.20m.com/IROC.html
and even better
http://www.iroc-z.com/flashlight/how...body/body5.htm
Old Apr 20, 2003 | 07:37 PM
doug791's Avatar
the second link was exactly what i wanted to know thanks a lot
Old Apr 21, 2003 | 06:54 AM
IZ28's Avatar
http://www.thirdgen.org/newdesign/tech/techdb.shtml
Old Apr 21, 2003 | 08:30 AM
Jim85IROC's Avatar
As usual, iroc-z.com's info is incomplete.
In addition to the billstein shocks & struts, & 16" wheels, the IROC also got a wonderbar, different steering box, single color paint scheme and unique decals.
Old Apr 21, 2003 | 08:36 AM
94z'sson's Avatar
does an 87 IROC have a wonderbar and where is it located on the car
Old Apr 21, 2003 | 10:22 AM
87DJP2001's Avatar
Its a steering box support (not wonderbar) . Location in front of car above the sway bar. Stop before you ask what swaybar.
Old Apr 21, 2003 | 04:24 PM
Jim85IROC's Avatar
It's called the wonderbar and it does a lot more than support the steering box, in fact that was a secondary benefit if any. Most IROCs still have a crack in the frame near the steering box. The wonderbar was designed to reduce flex in the front end during cornering. This benefits the handling by keeping the front-end geometry more true, plus puts less strain on the steering box & the frame behind it. All IROCs had it.
"The front structure is reinforced with a new crossmember, that the engineers call the "wonderbar"; bolted in place just below the front anti-sway bar, it stiffens the car's front structure during high-g cornering." Car And Driver, October 84.
It may or may not be called the steering box support from GM, but it's known almost universally as the wonderbar.
Old Apr 21, 2003 | 04:25 PM
Lungz's Avatar
how much better is the steering box for the IROCs compared to the z28?
Old Apr 21, 2003 | 04:34 PM
Jim85IROC's Avatar
It's not any better. It just prevents the wheels from turning quite so far so that the 245 50 16 tires don't rub the inner fenders. I don't believe the ratio is any different.
Old Apr 21, 2003 | 04:58 PM
87DJP2001's Avatar
May be it should be called the WONDERBRA / WONDERBAR OR I WONDER WHAT IT IS. It should be called by the correct name and that is (STEERING BOX SUPPORT BAR ) get real.
Old Apr 22, 2003 | 12:57 PM
Jim85IROC's Avatar
Complain to the GM engineers, not me. That's where the name came from, and regardless of what you think it should be called, it's known as the "Wonderbar". You and the guy behind the parts counter are the only 2 people that know what the hell a steering box support bar is.
Old Apr 22, 2003 | 01:37 PM
87DJP2001's Avatar
And you make THREE! Also Vendors such as
TOPS DOWN SOLUTIONS & SPOHN PERFORMANCE as two examples. You should also inform them of the correct name for the WONDERBAR (AKA steering box support) in their Catalogs..
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
capebuf
Jan 13, 2015 07:22 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
