intake help
Old Jan 14, 2011 | 02:51 PM
CHEEK08's Avatar
intake help
I just went to change the thermostat in my 84 z28 and for starters there wasent even a thermostat in it! and then one of the water neck bolts was broke off in the intake manifold! what should i do??
Old Jan 14, 2011 | 06:28 PM
byrons1502's Avatar
Re: intake help
I would drain as much antifreeze as possible, I put 3/8 nuts over the broken bolt and weld them to the broken bolt through the center. then slowly work the bolt back and forth until it comes out. It normally takes 1 to 10 nuts before it is done. Be very careful antifreeze is flammable. You could also try to drill the center and use an easy out on it
LETZRIDE
Outside of United States
Jul 9, 2015 07:17 AM
MadMav
Jun 15, 2015 09:51 PM
jwade88
Jun 14, 2015 09:38 PM
Countryboychevy
Jun 13, 2015 02:49 PM
maybe2fast
Mar 26, 2015 08:34 AM
