Installing headers on a 3rd gen
Old Mar 11, 2006 | 01:56 PM
  #16
n8sz28's Avatar
Re: Installing headers on a 3rd gen
can you install shorty headers to a 85 z28 without having to redo the entire exhaust system. if anyone has a part # or just a header name that you can install on a camaros stock exhaust with y-pipe that would be great thanks
Old Mar 11, 2006 | 04:37 PM
  #17
Kevin91Z's Avatar
3rd Gen Tech Moderator
There are no headers made that bolt to your stock y-pipe. You need their headers and their y-pipe. Almost all of them will bolt to your stock cat, but its better to put in an aftermarket cat and exhaust at the same time.
Old Mar 12, 2006 | 09:24 PM
  #18
85_305's Avatar
Yep. Plus, the stock y-pipes are absolute JUNK
Old Mar 13, 2006 | 12:19 AM
  #19
V8Rumble's Avatar
I completely agree - if you look @ the stock exhaust, you'll see that it's not even a "Y" - it's more of a crimped-up, poorly-designed "T". If you were to try to continue to use that, you'd lose 50% - 70% of the value of the headers...
Old Mar 15, 2006 | 09:47 AM
  #20
Z28Horn's Avatar
Originally Posted by 85_305
Although you are 110% correct, it really comes down to which motor he has. He will see more gain w/ headers/full exhaust on a 305 than a 350.
How is this? When my 91 formula was stock w/ the l03, i gained .45 seconds in the quarter from hedmans, true dual 2.5" exhaust. Then i put pacesetter long tubes and ORY pipe and a magnaflow catback on my 96 Z (which has the LT1) and i gained .6 - .7 seconds in the quarter from that alone, which would make the gains from the 350 slightly more.
Zach
Old Mar 15, 2006 | 10:02 AM
  #21
beast85's Avatar
if you are lookin for good power hookers are great, for price heddman is far superior to edelbrock, and no one ever thinks about using them. i got long tube headers for my 89 for about $150
Old Mar 16, 2006 | 12:23 AM
  #22
thirdgenrallysport's Avatar
my headmen header fit right in. all i had to do was take the start off. took me less than an hour to install my headers.
Old Mar 16, 2006 | 09:52 AM
  #23
Rice Killer87's Avatar
Heddman shorties on 3rd gens are awesome,fit like a glove!
Old Mar 16, 2006 | 11:34 AM
  #24
white91formula's Avatar
i put shorties on my formula with ac with out moving the motor up... just have to disconnect the sterring knuckle/shaft and youll be alset
Old Mar 16, 2006 | 03:43 PM
  #25
riphc06's Avatar
sorry to hijack the thread but im installing the slp's right now on my 89 350.....how the hell did you guys get a big enough wrench on the bolts to tighten them enough? secondly i thought i read something about needing a differant MAF sensor a while ago....does anyone know anything about this? thanks guys
Old Mar 18, 2006 | 12:12 AM
  #26
raul.garcia's Avatar
I have the SLP 1-3/4" w/AI.R., the driver's side was a drop in, but I had to remove the air pump on the passager side and the header just slid in. My only problem is getting the #5, and #7 spark plugs in.
Old Mar 11, 2007 | 10:23 PM
  #27
86irockz28's Avatar
Originally Posted by V8Rumble
I'll second that. I installed my SLP 1-3/4" headers (which are bigger than the Edelbrocks you're talking about) on my car without raising the engine - I really wouldn't think that it would be necessary to do that for yours...
I don't know if there are any "secrets" per se, but I did a few things in an attempt to stave off problems down the line:
* Got a heat shield to go over my starter (had to clearance it to make it fit);
* Bought some plug wire heat shielding for the plug wires;
* Used Stage 8 Locking bolts to attach them to the heads;
* Used a better kind of exhaust gasket (the kind with graphite inserts in an aluminum "frame" - Summit has 'em) to seal them to the heads.
It cost a little extra, but I haven't had any problems since I installed 'em in 2000...
What length stage 8 bolts did you buy? where did you buy them? and what car did you use them on?
Old Mar 12, 2007 | 12:30 AM
  #28
quickchicken's Avatar
i have heard alot of neg on the edelbrock headers. me, i have a set of hooker 2055's and other than killer fitment i can say they dont need a gasket where the Y mounts to the headers and removal if needed is a snap.
one of the engineers in our F.A.S.T. dept installed a set of 2055's on his camaro and said they went in so well it was silly. he just had to remove the starter and it went stright in. the dr side went in from the top.
Old Mar 12, 2007 | 05:31 PM
  #29
85_305's Avatar
Zach
Quoted the wrong person Zach Wrong name for the quote ya made lol.
Yeppers. Heddman is AWESOME period!! I loved them on my 305, and it sounded mean as F*CK!
And yes. DO ditch the factory T, err Y Pipe
Old Mar 15, 2007 | 07:23 PM
  #30
94LT1Maro's Avatar
I'd ditch the Edelbrocks and go with Hooker Headers, & Y-Pipes. With the Y-Pipe Kit you'll even get a midpipe that deletes the Cat. I plan on finishing the job up with a Hooker Catback.
dmcdonald96
Jan 30, 2015 06:46 AM
4586
Dec 31, 2014 02:21 PM
Jul 4, 2005 05:00 PM
19redta96
Jul 23, 2002 12:25 PM
