I'm Not Sure This is the Right Forum for this Crank Question
Old Apr 19, 2007 | 11:41 AM
Ole Hippie's Avatar
I will ask this Question about a factory GM steel one piece real seal crank here 1st.
I'm looking for a 350 factory GM steel one piece real seal crank, I'm not sure what motors GM put them in. anyone know what the 1 Piece RMS steel cranks came in ? I've found one but or the money the guy wants I an buy a scat or eagle aftermarket.
can anyone help me out ? if I knew where to look I could prob snag one outa a local salvage yard. the salvage yard around here don't take the time to check out all the crank #s, so If I knew where to start looking I might find one around here.
factory 1 piece RMS #s
14088532...350.......forged..medium journal...3.48" stroke
14088552...350.......forged..medium journal...3.48" stroke
Ole Hippie
Old Apr 19, 2007 | 01:37 PM
LesPaulGoth's Avatar
Check out www.mortec.com and click on 'engine block casting numbers'. That should tell you which blocks had the one piece seals.
Old Apr 19, 2007 | 02:12 PM
Ole Hippie's Avatar
thanks but I'm wanting to know witch vehicles did GM put the 1 piece rear main seal blocks in that had the steel crank. I know the 86 and newer blocks are 1 piece RMS.......
I'm wanting to locate some Factory GM 1 piece RMS steel cranks and if I knew witch vehicle to look in it would be a big help............
Old Apr 19, 2007 | 03:23 PM
Ole Hippie's Avatar
I found this http://www.gmpartsdirect.com/perform...CATID=883.html
Old Apr 24, 2007 | 06:53 PM
ayers1967's Avatar
You should go to chevymania.com , E-mail them they will know.
Old Apr 25, 2007 | 12:56 PM
Anniversary-Z-man's Avatar
Hey Hippie...I've got one outta my '92 Camaro Z - L98 350...where are ya located?
Brandon Wittmer
Dec 20, 2014 09:51 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
ChrisFrez
Dec 15, 2014 03:09 PM
ChrisFrez
Dec 7, 2014 06:01 PM
JasonD
Jul 15, 2002 02:17 PM
