ignition timing
Old Jul 1, 2003 | 09:06 PM
CamaroZ28Coupe's Avatar
ignition timing
i know it sounds like a silly question and im not a complete newbie, but i need to adjust my timing because its too far advanced but i cant seem to locate the marks could someone let me know where they can be seen so that i can use the timing light. does something need to be removed to see them? my car is the 83 z28 black with gold ground effects
Old Jul 1, 2003 | 09:13 PM
slayer6x6's Avatar
The timing marks should be on top of the harmonic balancer and to the right a little bit.
Old Jul 3, 2003 | 06:04 PM
thanks for the reply but im still havin trouble seeing them. it seems like the water pump and the belts are in the way? i dont need to remove anything to do a timing job right?
Old Jul 3, 2003 | 06:42 PM
irocz383's Avatar
If you stand on the driver side and hunch over looking between the steering pump and under the water pump you should see the timing marks near the top. If its stock the marking tab is stamped on the timing cover. It may be dirty... some steel wool will do the trick.
liamcg97
Nov 25, 2019 05:55 PM
97Z28Muscle
Feb 6, 2015 10:44 PM
Dzmaro
Jan 25, 2015 10:39 AM
Ari G
Dec 11, 2014 03:21 PM
