IAC Question
Old Mar 24, 2009 | 08:49 AM
sobo's Avatar
IAC Question
Hi Guys,
I removed my IAC to determine if I had a problem with it, cleaned it, shorted my A and B circuit and plugged the IAC in. When I turned the key that pintle shot out half way across my yard.
I know I should've had something in front of it to check for movement but is it supposed to fly out of the housing?
Thanks for any help.
Sobo
Old Apr 12, 2009 | 05:46 PM
Gord's Green Z28's Avatar
Yeah, that's happened to a few people who've tried that test. If you're going to clean the IAC, I'd recommend taking the throttle body off and cleaning it out as well. Take the air foil out if you have one and clean behind that as well.
Once you've put the IAC lever and spring back together and screwed it so they're both as compressed as possible, simply put the throttle body and IAC back on the car. Turn the key to ON but don't don't start the car. Wait about 4 seconds and you'll hear the IAC go "plunk." When it does that you'll know that it's adjusted itself back to where it should be.
HectorM52
Jul 30, 2017 11:46 AM
lt1matt
Mar 21, 2015 07:35 PM
grgguy
17
Feb 23, 2015 07:57 PM
Red_94Formula
Jan 22, 2015 12:17 AM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
