I need help with posi question.
Old Apr 27, 2006 | 02:24 AM
Solidous_Snake's Avatar
I have a 1987 Iroc camaro with a 10 bolt differential. My question is did the 87 irocs come with a 26 spline or 28 spline axle? And which of the two can I run 3.73 or 4.10 gears in?
My car has been non running because I can't figure which I have so I can replace the broken one. Please help!
Old Apr 27, 2006 | 07:20 AM
87DJP2001's Avatar
Re: I need help with posi question.
You have 26 spline axle shafts and what gears you can use depends on the series carrier you have. And my guess its a 2-series. And the RPO code For a Limited Slip rear is G80.
Old Apr 27, 2006 | 07:25 AM
snod83's Avatar
I'm not sure what splined axles you have, but they have nothing to do with the gearing that you can run. You can run any gear ratio as the ring bolts to the carrier, and the axles lock to the carrier (simplified, actually they lock to the posi unit....). If its broken, why don't you pull it apart and start counting to make sure you get the right answer?
Ryan
vwb11356
Jul 22, 2015 06:51 PM
Latronaxe
Jul 20, 2015 12:00 PM
mrwz28
Jul 8, 2015 09:11 PM
cristian1311
May 1, 2015 08:56 PM
