I need help with getting my 1988 tpi TA to run into the 8"s in 8th mile ?
Old Mar 17, 2008 | 09:34 AM
Brian Foster's Avatar
Question I need help with getting my 1988 tpi TA to run into the 8"s in 8th mile ?
I have done some work.UMI rear suspension,new chip,pulleys,new valvesprings and 1.6 roller rockers,This is a 350 car with 3.27 gears.It runs 9.04 to 9.06 now. It ran 9.60 before this.
Old Mar 17, 2008 | 12:06 PM
Marc 85Z28's Avatar
Drag radials on stock wheels and a looser converter should be worth near a half second.
Old Mar 17, 2008 | 03:59 PM
Rice Killer87's Avatar
DR's,headers/exhaust,gut the stock air boxes,and an adjustable fuel pressure regulator.
Old Mar 17, 2008 | 07:06 PM
Smile I for got to tell you some info.
I have weld wheels and slicks,I have shorty hedders not on car yet,and NOS plate kit to install,but want 8's on motor.I have ordered the lower control arm relocation kit to install to help 60 foot times.
Old Mar 17, 2008 | 10:18 PM
Marc 85Z28's Avatar
In that case install the headers and a Precision Industries Vigilante 2800rpm stall torque converter.
Old Mar 17, 2008 | 10:49 PM
Zepher's Avatar
I would say gears, but gears for a 9 bolt are pricey. If you do go with gears, go 3.77's since you probably won't notice any real difference going with 3.45's.
Slap a Holley Stealthram on there, about $500 and comes with new fuel rails (you just need to clearance the underside of the hood a tad if you still have the stock hood).
You should see a nice improvement when you install the headers.
Old Mar 18, 2008 | 05:11 PM
AutoRoc's Avatar
Marc's right!
2800-3000rpm Yank or Vigilante torque converter
My advice..no matter what vehicle is: Drag radials+Converter+100 shot=
Old Mar 18, 2008 | 05:14 PM
mdacton's Avatar
headers and cam. converter and gears.
Old Mar 19, 2008 | 10:13 PM
LB9GTA's Avatar
What is your 60ft time?
Do you have traction problems?
Get a set of lower control relocation brackets(lcarbs) and box your lower control arms too.
Inbolt your front sway bar for better weight transfer.
If you want an extra tenth of a second, put a switch to disconnect your alternator. I did this and it netted me a tenth.
Feffman
Oct 9, 2015 05:42 AM
capebuf
Jan 13, 2015 07:22 PM
Jazsun
Dec 29, 2014 12:14 PM
Lederman1976
Nov 30, 2014 05:21 AM
