I need a door hinge
Old Nov 15, 2003 | 11:36 AM
firebirdjosh's Avatar
I need a door hinge
My driver's side door barely closes anymore. The lower hinge's pin is really screwed up. Can I get that pin easily? Also, how hard is it to install? I am sure this is a common thing, so could someone please help me? Thanks alot.
Old Nov 15, 2003 | 12:13 PM
95NateZ28's Avatar
The hinge is welded to the door, and bolts to the car. I started to rebuild mine, but then I gave up and just adjusted the door so it closes correctly. I even had to file the rear post hole (where the latch is) so it would move up further.
EDIT: Not file the post, but the quarter panel for added adjustment room.
You can buy bushings at Autozone for like 5 bucks, but have fun putting those in as it is a bit of a PITA.
Old Nov 15, 2003 | 12:41 PM
krazzycowgirl's Avatar
When Replacing a pin or doing any door work you SHOULD have another person there with you at all times.
I know this is for a 2nd gen but it also works for ours for the most part.
http://transamtech.com/doorpintech.html
Old Nov 15, 2003 | 03:58 PM
The top of my pin is bent so maybe bushing will help. The hinge is fine otherwise. Here is an ebay item i was looking at. Do you think it would work? Thanks for the replies so far.
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2439897865
Old Nov 15, 2003 | 06:53 PM
89 Drop Top's Avatar
I believe www.3rdgensolutions.com sells a door hinge repair kit that's real sano. You can get greasable bushings, or non greasable ones. Hope this helps!!
Old Nov 15, 2003 | 11:04 PM
Thanks, but that is the upper door hinge. My problem is with the lower.
Old Nov 16, 2003 | 02:42 PM
Does anyone know where I can get that lower pin?
Old Nov 16, 2003 | 02:59 PM
Dave89IROC's Avatar
ummmm
the lower pin should be avalilble from any auto parts store, it is the upper they can't get
Old Nov 16, 2003 | 04:22 PM
Great, thanks.
Old Nov 18, 2003 | 03:15 PM
Marc 85Z28's Avatar
I got 2 lower pins and 4 bushings from my local Chevy dealer for only $14 total. Install is much easier than everyone claims. I completed BOTH doors in under 45 minutes. The only special tool needed is for the detent spring. MAC tools sells one cheap (less than $20) that works great.
FYI - If your pins/bushings have been worn out for a long time, your door latch is probably also shot. I found my doors rattling horribly over bumps after the pins/bushings. Turns out the latches had ovaled out the retainer arms. New latches set me back $100 for the pair new
Aaront810
Aug 29, 2020 09:34 PM
2QUIK6
Sep 17, 2016 02:31 PM
RUENUF
Mar 13, 2016 03:37 PM
IndyZman
Oct 22, 2015 02:17 PM
z28cam1993
Sep 9, 2015 04:08 AM
