Hypertech Fan Switch!!!!
Old Mar 13, 2004 | 06:25 PM
buzz12586's Avatar
I got the Hypertech fan switch 176 on 166 off and I tried to install in on my car today. We drained the coolant and pulled the old switch and guess what? The bolt size of the new switch and the size of the old one are different. This is really messed up. Anyone else have this problem?????
Old Mar 13, 2004 | 06:40 PM
PyRo9862's Avatar
Ive heard they have to be installed into the radiator or somthing like that.
Old Mar 13, 2004 | 09:41 PM
lordmetalz28's Avatar
i think you musta got the wrong part number i have an 87 iroc-z and she fit right in the block on the passengers side with no problem. so return get another one and you didnt listen to like i said mines on at 200 and off at 186 and its always running except on highway use. your never gonna get that car down to 166 no matter what you do. your just gonna run the fan for no reason.
Old Mar 14, 2004 | 12:05 AM
IROC-T's Avatar
Yeah! What he said.....
Old Mar 14, 2004 | 08:16 PM
buzz12586's Avatar
So I should return it and get the one that is on at like 186 or something????
Old Mar 14, 2004 | 08:29 PM
buzz12586's Avatar
Should I just set up some wiring to a switch inside the car??? Would that be easier cuz then I could turn it on or off whenever I wanted to???
Old Mar 14, 2004 | 08:34 PM
seriously bro get the on at 200 off at 186 youll be much more well suited with it. it still probably wont turn off unless your on the highway but ive never been more happier with a mod in all my life and make sure you specify to jegs your application seems to me they sent you the wrong one. good luck
Old Mar 14, 2004 | 11:54 PM
IROC-T's Avatar
I'd send it back and get the JET switch, and a 190* high flo thermostat ,this combo works nice..
Old Mar 15, 2004 | 07:43 PM
buzz12586's Avatar
I already have the different thermostat. Where can I get one from JET?
Old Mar 15, 2004 | 08:04 PM
Brett H. - 89GTA's Avatar
I have the 200/186F unit since I have a 180deg thermostat. It works great. The hex that the socket goes on is a different size than the stock one, but the thread size is the same. Just use a different size socket when you tighten up the new one.
Old Mar 24, 2010 | 10:39 PM
88i-roc's Avatar
i actually had the same problem on my 88 iroc
and i tried the jet and the hypertech brands fan switches
and both of them were the 185 switches
and both their sizes were bigger then the switch i actually have in the block
someone told me i can try connect it to the water pump instead of the plug but there is not enaugh room overthere because of the metal fuel lines
so right now im stock as well and trying to figure out how to get that 2nd fan work on low temp automaticly
Old Apr 4, 2010 | 10:50 AM
stanghunter211's Avatar
my jet fan switch went in no problems. AFR heads
Jeff'SS
Jun 1, 2015 06:21 AM
cristian1311
Nov 23, 2014 02:22 PM
troywg
Sep 12, 2002 07:28 PM
slothgrant
Aug 22, 2002 03:01 PM
