HSR and LT4 hot cam
Old Mar 8, 2006 | 11:41 AM
cc89formula's Avatar
HSR and LT4 hot cam
anybody running this combo on stock heads? i should be putting the cam in either this weekend or next. does anyone have any dyno sheets or time slips? im wondering what kind of power im going to be making. i ran 14.88 here which at sea level would have been about a 14.2X. im hoping to run a 14.45 or better here, anyone think thats possible? or am i going to be disappointed?
Old Mar 9, 2006 | 02:22 PM
Re: HSR and LT4 hot cam
nobodys got anything for me?
Old Mar 9, 2006 | 02:57 PM
klumb15's Avatar
thats a pretty hot cam for stock L98 heads...i'd be careful, I heard you shouldn't go over .490 lift on stock valvetrain, and I believe the hot cam is .525 lift...
a LT4 hotcam, HSR, and decent heads(ported alum. L98's, mediochre type of heads) can go low 13's, high 12's possibly....probably mid 12's with some nice AFR heads or something...
Old Mar 9, 2006 | 02:59 PM
Zepher's Avatar
hotcam is .525/.525 with 1.6 rockers. With 1.5's it is .490 somthing.
Old Mar 9, 2006 | 05:05 PM
ill be using 1.5s so its going to be like .495ish...and ill be using the LT4 springs
Old Mar 9, 2006 | 05:18 PM
klumb15's Avatar
gotcha...should work then...i would expect somewhere in the mid 13's if your using stock L98 iron heads...
Old Mar 10, 2006 | 12:21 AM
Kevin91Z's Avatar
3rd Gen Tech Moderator
Make sure you check your valve spring clearance. Those stock LT4 springs are barely adequate for that cam's lift.
djangoroar
Parts Wanted
Feb 21, 2015 11:47 PM
GigaMp3z
Feb 20, 2003 02:57 PM
Speeds8erM-1
Aug 15, 2002 10:07 PM
Speeds8erM-1
Aug 13, 2002 10:24 PM
Speeds8erM-1
Jul 28, 2002 06:18 PM
